Question about Refrigerators
Icemaker is not making any ice after freezer defrosting, how long should I wait ?
This is a Kenmore side by side model # 106 5661 2500
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
Normally a new batch of ice is produced every two hours or so. The ice maker will not eject any freshly made ice until the interior temp of freezer is about 10 degrees; at that point the thermometer will close and initiate the ice ejection and the other steps to make more ice.
Posted on Nov 28, 2013
4 Suggested Answers
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
SOURCE: Kenmore Coldspot Model #71182100
water under crisping bins
Posted on Jan 25, 2010
We can't get our icemaker to work in our Kenmore bottom freezer refrigerator-model 795.7160. It is not making ice-you can hear it go through the steps and even dumps, but there is no ice.
check your water line and filter. Defrost the freezer in case its frozen. Also check the water line where it enters. Check for leaks under the valve. Otherswise you may have a bad icemaker.
Jan 10, 2018 | Kenmore Refrigerators
Kenmore Side by Side 56563400 Refrigerator no ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 25, 2011 | Kenmore Side by Side Refrigerator
Kenmore Side by Side Refrigerator no ice
NOTE: This
Leo Ponder
imufo2
Kenmore side by side frig freezer .ice maker won't make ice and red light inside next to ice maker is blinking
NOTE: This
Leo Ponder
imufo2
Sep 15, 2011 | Kenmore Refrigerators
Model 106.54532400 Side by side Kenmore. Ice maker no longer works
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Aug 16, 2011 | Kenmore Refrigerators
Model 10658176702 with the icemaker not filling and not making ice.. everything else seems to be ok.. the ice maker does not have ice in it. but water still is dispensed
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 07, 2011 | Kenmore Side by Side Refrigerator
Icemaker not making ice
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | Kenmore Side by Side Refrigerator
Have a side by side kenmore ref. and the ice machine is not making any ice. The ice maker switch is on and I am getting water. Model on my manual reads 106.58916801. any suggestions.
Hi and welcome to FixYa. I am Kelly. Having determined your icemake is PN W10190960 , here is a link that will help you test your icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The steps are pretty straight forward and will isolate exactly which component of the icemaker / system has failed.
I would like to note that these icemakers are very reliable. They do occasionally fail but most of the time the problem is the freezer is not defrosting properly so the airflow through the freezer is blocked by ice build-up in the evaporator coils due to that defrosting problem.
Your unit has an electronic control board that controls the defrost circuitry.
If you check out the icemaker assy per the first link and still have the problem I would recommend doing a manual defrosting by unplugging the unit. Then remove the contents of the freezer section and place a fan blowing into the freezer section for just over 2 hours. This makes a water mess so be prepaired.
After the manual defrosting cycle restart the unit and reload the freezer contents. After about 12 hours check the icemaker to see if it made any ice at that point. If this solves your icemaking problem it will only be temporary if you still have an automatic defrost cycle problem. Your unit should defrost at least 3 times in 24 hours.
Thanks for using FixYa.
Kelly
Apr 01, 2010 | Refrigerators
Ice maker not making ice
www.hometips.com/repair-fix/freezer-ice-maker.html
please Visit the site..its will help you step by step.. regards.. do rate me..
Aug 01, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
