Setting up port forwarding - Computers & Internet
Port forwarding instructions
Port forwarding used to forward a port request from wan side to local systems on lan to use specific services provided by servers.
go to Setting, use Port forwarding option. Now click on Add. Enter the Local Ip address of system providing the specific service and then add the starting port number and ending port number, (it may be same). Now click on Save.
Aug 17, 2014 | NetComm Computers & Internet
I can not play xbox because security is to high how do i chance it
you need to give your xbox a static ip address.
on your linksys router go to internet explorer. browse to http://192.168.1.1
default login is blank password is admin
go to Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074. Go ahead and enter the settings shown above into the Port Range Forward menu.
port forward the following ports up above to the ip address that you set your xbox 360 to.
Apr 03, 2011 | Linksys WRT120N Router
Need to know how to change the nat setting off of strick on my virginmobile mifi2200 to play xbox 360
You need to go into the port forwarding section in your administrator settings, you should be able to access that by going to 192.168.1.1 and finding the port forwarding section, you then must forward the ports that the Xbox 360 requires to go online;
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
Mar 04, 2011 | Video Game Consoles & Games
How do you set port forwarding
This is an excellent generic guide as I can find no port forward info in the manual for your device..
If your device supports it, this guide will help you..
http://www.wikihow.com/Set-up-Port-Forwarding-on-a-Router
Dec 09, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
HOW CAN I FORWARD A PORT? THIS ROUTER IS NOT LISTED IN PORT FORWARDING APPLICATIONS LIKE SIMPLE PORT FORWARDING ETC.. OR SUGGEST ANY OTHER WAY TO FORWARD PORT
In order to get to the page you need to port forward you need to know your default gateway.
Usually:
192.168.0.1
192.168.1.1
192.168.2.1
Enter those into your web browser, if nothing comes up then go to Start. Then click run(or search if you have vista) type "cmd" then type in ipconfig
Start>Run>Cmd>Ipconfig
There is where you can see your default gateway. Enter that into you browser. I t might ask for a password, it's usually admin.
Also a lot of the port forwarding issues are due to your firewall settings. Make sure you add the ports to there as well.
Jul 10, 2009 | Computers & Internet
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Port Forwarding on Bigpond 2071a
you need to go into the modem settings and open a port.You set a number 32599 and apply works perfect for me and then got into preferences at utorrent and set the 32599 number and apply now check to see if your port is open.
Aug 21, 2008 | Computers & Internet
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Port Forwarding with BR-6104K
hope this helps
In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
I have not run into CABLE providers cable modems having to do this
did you allow that port in your computers firewall?
Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
instruction site
http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
