Question about Panasonic KX-TGA670B 5.8 GHz Cordless Expansion Handset
Syncing kx-tga670b heandset to base
I can't sync handset to base
mrfixit64857
  • 9 Answers
SOURCE: sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Posted on Jan 01, 2009
  • 512 Answers
SOURCE: Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
Posted on Jan 09, 2009
  • 569 Answers
SOURCE: how to program handset to the base? Panasinic KX-T7730
I have uploaded the user manual for you.
Go here and download. This manual covers the 7730.
http://www.easy-share.com/1909338845/Panasonic KXT7700-User-Guide.pdf
Posted on Feb 19, 2010
  • 3 Answers
SOURCE: KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Posted on Sep 23, 2010
bbl242003
  • 1637 Answers
SOURCE: Cannot sync phones to base I own a panasonic
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 18, 2011
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
GE handset 28101 will not sync with base-GE 28129
Unplug power cord from the base for ten or fifteen minutes, this is the only user level operation that you can do to try fixing the problem.
If after resetting the base still do not find the handset, then either the base or the handset is faulty.
If the base works fine with a different handset, then it is the handset.
Sep 14, 2008 | Lands Phones
Sync
If by "sync a handset" you mean register a handset so it works with the base, then yes. It doesn't even need to be the same model. The manual gives instructions for registering a handset to work with the base. If you need a manual, select the model of your Uniden DECT 6.0 phone from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl .
Jun 03, 2013 | Uniden DECT 6.0 Cordless Telephone...
How do i sync my vtech CS5111 to its base...please help...
have the main based plugged into a working ac outlet and active telephone line then place phone on base for 1 minute then remove base should sync within that time
Mar 18, 2010 | Vtech Lands Phones
Sync a new handset to kx-tg5632 phone
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
indicator flashes.
minute.
3 Handset:
sounds.
4 {OFF}
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Dec 12, 2008 | Panasonic KX-TG1100 Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Couldn't make any calls
You might try unplugging the base AND removing the batteries from the handset for 30 minutes. Then reinsert the batteries, place the handset in the cradle in the base, and then plug the base back in. This might allow the handset and the base to re-sync with each other.
Mar 15, 2007 | Panasonic KX-TG2740S Digital Answering...
Panasonic KX-TGA670B 5.8 GHz Cordless Expansion Handset Logo
27 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
