Need a four digit code for ge remote
Need a code to program my sony blue ray player
  • 514 Answers
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Posted on Apr 02, 2015
Ge universal remote 24991
Look in this PDF of the manual for the code (all the way at the end). If you don't find what you need, look in the Auto Code Search section on page 8 to see if it can figure out one that works.
http://www.homedepot.com/catalog/pdfimages/29/29baf34c-aa24-40e3-af86-68616fea3bdf.pdf
Nov 27, 2013 | Sony HESV1000 200 Disc Blue-Ray Server
Not printing properly
i have a ge universal remote 24991 model and i need a code to program this remote for my sony blue ray player
Nov 27, 2013 | Polaroid Photography
How to auto program a phillips universal remote to a memorex blue ray player?
0483,0481,0488,0497 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | Philips Phillips SRP1103/27 3-Device...
Need to re-enter codes for Samsung blue ray player remote control AH59-02298A
2974,2954,2977,2933,2922. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 16, 2013 | Samsung Televison & Video
Sony blue-ray
go to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jun 24, 2012 | GE JASRM24912 Remote Control
I need the 3 digit code for ge universal remote model RC24912-A for sony dvd player
Code lists and manuals for GE remotes are available from http://www.jascoproducts.com/support/universal-remote-codes.asp . The 3-digit code list is here: http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf . The Sony DVD player codes to try are 166, 320, 321, 322, 361, 389, 399, 909 . (Sony DVD recorders may use 302, 321, 322.)
However, the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a newer universal remote.
I hope this helps.
Jul 24, 2011 | Universal Remote Control GE174Universal...
I need the code for ge universal remote rc24993-c to connect to a sony television please
Universal remote allow you to control multiple electronic devices with a single remote. You can use the remote to work your TV,DVD player, cable boxes and other devices from the comfort of couch.Philips is a popular manufacturer of universal remotes.to program a GE remote for SONY TV,you will either need to input the device code or perform a code search
direct entry
first.turn on your TV manually. next.press down and hold set-up on the remote.the red indicator light will stay lit.after that.press the TV device button to let the remote know you wish to program a television then.enter your device four digit codes on the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the number zero in the beginning of the codes finally.test the remote to ensure it works.with the turned on,press the channel button and see if the TV responds..if it is work the remote programmed and you are done,if it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
Mar 09, 2011 | Televison & Video
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Aug 13, 2007 | Sanyo DWM-390 DVD Player
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
