Question about Garden
Electric starter not turning motor over
Extension cor is giving juice but stater does not turn motor,sometimes it **** a little
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Last time I checked a leaf blower didnt have an electric starter so would you be as so kind as to tell us what your dealing with
Posted on Dec 30, 2013
Stater spins but engine doesn' t turn over
Bummer. This is typically one of two things: starter drive, or teeth missing on the flywheel.
Of course, something can be cracked or loose, but surgery is the next step.
Feb 24, 2015 | Cars & Trucks
Why wont my 1995 dodge caravan start , i turn ignition on all normal lights come on the dash as usual and i here fuel pump engage but when i turn the key it wont turn over at all and battery is good a
Check starter motor, give it a smack with a hammer, might turn over after that, this is a sign the stater motor brushes are most likely worn out. Or and check ignition switch below the ignition barrel.
Oct 20, 2014 | Cars & Trucks
Heintermittent starter problems, 2000 beetle
There may be a dead spot in the starter. If it just clicks my recommendation is to replace the stater before it stops working all together. Good luck.
Aug 23, 2012 | 2000 Volkswagen Beetle
When i turn the key forward the engine wants to start but doesnt just makes the roaring noise and doesnt start
It could be the starter, is it high pitch screeching, metal against metal, sound? Or more of whine? If it's metal against metal, the teeth on the flywheel ring gear might be damaged. If it's a high whine you are probably hearing the electric motor part of the stater and the "starter drive" is bad. The stater drive is part of the starter, it's the gear that engages with the flywheel gear. It is a one way clutch, it is supposed to hold when the starter is turning the engine. But, freewheel when the engine starts so it doesn't over rev the starter motor. When the drive goes bad it freewheels both ways. If you think the flywheel teeth are damaged you could try turning the engine by hand a little, WITH THE KEY OFF! Sometimes you can put a wrench on the alternator pulley nut and turn the engine a little. This will move the damaged teeth away from the starter and it might work now. Good luck.
Mar 12, 2010 | 1991 Chevrolet S-10 Blazer
Bike has electrical issues
You hooked something up wrong. Go over your connections and grounding. It sounds like the starter is not getting juice. Is the starter grounded properly? Is the juice not getting to the starter? Is the problem maybe in the switch or another connector before the starter? trace all your wires, looking for connectors that may have vibrated apart. Check your battery charge level.
Oct 05, 2009 | 2005 Suzuki Boulevard C90
1990 Volvo 249 DL Stater issue !
pull starter and clean, check stater solenoid, check all electrical connections
Sep 13, 2009 | 1990 Volvo 240
Caddy Deville wont start
Check the gear selector switch. You may need a Chilton's book to find it. Try starting in neutral.
May 04, 2009 | Dell Inspiron 2650 Notebook
Stater for a jaguar xj8l 1998
starters is mounted on the bottom of engine. its a little long electric motor with a little drive gear that mesh to flywheel to turn engine over to crank.
Apr 29, 2009 | 1998 Jaguar XJ8L
My 2004 accord won't start. Battery is fine and usually when stater goes out you hear a clicking mine makes no noise. When you turn the key it goes from plenty of juice to no juice no sound. What should I...
You said the battery is fine, does that mean you ran a load test on it? If the battery is fine, it could still be the starter I have had a starter just quit before and not make any noise. I have also had wires come loose on the starter and have had the ground get loose and grungy.
Apr 26, 2009 | 2004 Honda Accord
92 jeep wont turn over
do you have connection at the battery? have you checked fuses and the alternator? hope that helps sometimes fresh ideas work
Dec 09, 2008 | 1998 Jeep Wrangler
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
