Question about Zanussi Washing Machines
Washer not working
Washer blew the electrics and has not started since, the on/off button is on though
    Genius:
  • 1,198 Answers
You may get new electrics at Repairclinic.com, but you still have to find out why they blew. Get the parts and call a repairman.
Posted on Nov 28, 2013
Karcher electric pressure washer help starting
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
Sep 18, 2015 | Karcher Garden
Why won't my washer start?
with the machine switched on push and hold any two buttons for at least 30 sec.the machine will reset.adrian.
Jul 14, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Won't start after running fine
You tested it on other outlets? Check the motor for reset button?
May 02, 2013 | Karcher Garden
Motor burn out even though no disruption to water supply.
if there was water going through pump when motor has cooked then it may have been an electrical problem. it may have been your power supply or ext. lead. or the capacitor blew.
motors can burn out if left on and the trigger not being squeezed.
Jan 10, 2011 | Karcher K2.26MR Electric Pressure Washer
My kenmore elite he3t washer and dryer are not getting any power. The electrical outlet they were plugged into blew. I have plugged them into another outlet and they do not come on. Is there an internal...
yes there inside of the machineunplug machine from wall take cover off follow power cord goinging into washer should be a button to push in there
Dec 05, 2010 | Washing Machines
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
Started washer, heard 'pop', water started coming out of bottom
Thats not good. Sounds like the seal blew out. Inside the unit there are seals that seal up the parts where they are bolted together. Also there is the pressure connection that could have blown out as well. To determine which is the problem you will need to dissassemble it.
Jun 22, 2010 | Karcher K 593 M Electric Pressure Washer
Worked well, then blew the fuse.
What you should do next is stop using an extension lead. As you've already discovered, there's a risk of the connection getting wet, which is potentially very dangerous, but this is probably not the main problem. Most extension leads (the normal domestic type) are simply not capable of carrying the current needed to run your pressure washer.
Rather than using an electrical extension, use an extension high-pressure hose and work further away from the machine (which also makes it easier to keep the machine dry).
If this doesn't sort the problem, please post here again and we'll try something else.  Good luck!
Mar 10, 2009 | Karcher K2.26 Electric Power Washer
Washing Machines Logo
22 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
