Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Not Drying We have a Kenmore HE3 Dryer. The dryer runs perfectly, but doesn't dry clothes as properly as it should. Does anyone have a recommendation?
  • DeanieF Dec 27, 2008
    I have the Kenmore He3 dryer and it seems to take forever to dry clothes.  It does heat up, but have to run several cycles to get items dry.  I have tried small loads and larger loads and have the same problem.  Thanks for your help!
Had the same issue with my Whirpool. If the clothes are getting hot but not drying then there might be a build up of lint in the exhaust duct and/or passage. Once I replaced the the duct and ran a snake with a brush through the passage (my dryer was on 1st floor, vent ran up to 2nd) and cleaned out the lint build up in filter area it worked like new. Also keep in mind if you use dryer sheets they will leave an invisible residue on your lint filter thus restricting airflow. This can lead to the heating element burning out. The lint filter should periodically be scrubbed with a soft brush (an old toothbrush will do) under warm water with detergent (I use Dawn). This should keep the airflow moving through the dryer instead of keeping it in the drum. Hope this helps.
Posted on Oct 11, 2007
SOURCE:
Dryer beeps running
Hello Biff
You should the the following.
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
Best Regards
Neciforo Llanto
Sep 21, 2013 | Kenmore Dryers
Have an HE3 Kenmore elite gas dryer. It is taking longer to dry the clothes than it did when it was new. Is there any maintenance I can do to improve the time?
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Aug 03, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Felt 'washer' coming out of front of kenmore he3 dryer. dryer is not drying clothes. 2-4 cycles for a small load
Typically the problem you are having is caused by lint in the vent pipe or a partial blockage where the dryer vent ends out doors. pull out the dryer, remove the vent pipe and check it all out. then go out doors and check from that end
Jun 08, 2009 | Kenmore 82822 Electric Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Electric HE3 dryer not drying
Please click on the following link for advice on a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Please read through the link thoroughly. Check the power source at the outlet, first, to ensure you have the proper voltage prior to disassembling the dryer. It should read 220-240 VAC across the two hot leads (this would be the RED and BLACK terminals at the terminal block in the back of the dryer if you choose to check there). Then, inspect your ducting to make sure its not clogged or kinked anywhere. If you have questions, please post back and let me know. I hope this helps you.
Aug 04, 2008 | Kenmore Dryers
Kenmore he3 electric dryer has F1 error code while drying clothes. dryer will run for a few minutes and automatically shut off. purchased a new thermostat but can not find where the thermostat is located...
How to disassemble a kenmore dryer to get the drum out. Can someone tell me please. I want to know what I need to take off first so I don't mess anything up.
Jul 10, 2008 | Dryers
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
137 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
