Question about Zanussi ZWF1430W Front Load Washer
No control lights are on just the on/off button is lit up
Just blew electrics and has not started no lights lit
Model GFSS6KKXASS. How can it be reset?
our electricity popped off and then right back on, then the fridge started flashing 88's. Figured it blew a fuse, but then I held the energy saver button and alarm/light buttons for 10 seconds and the fridge started working again!
Sep 29, 2015 | GE Refrigerators
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
No power, lights
You need to check the Main PWB Assembly for the LED light being lit. If it is not lit the board needs to be replaced
Aug 13, 2009 | LG WM-2277HW Front Load Washer
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore range control panel not working
sounds like the control board blew on you replace it.
Dec 16, 2008 | Kitchen Ranges
Zanussi ZWF1430W Front Load Washer Logo
18 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
