Question about Garden
My chain is loose
How do I tighten it? I've never tightened a quad chain before.
    Problem Solver:
  • 15 Answers
LOL.....Don't panic...
There are 2 nutz on the chain/bar side of the saw.
You must loosen first, then locate the adjustment screw (reg flat screwdriver) on the end of the bar and next to the 2 nutz you loosen at the bar/chain.
Best to set saw flat and support the end of the bar/chain, tighten chain to a point where you pull on it and it can be pulled about 1/4 inch from bar with medium strength, "snug" I like to call it.
re-tighten your nutz after adjustment.
NOTE: I have found that when you support the end of the bar it raises it a bit, after you tighten your bar the tension increases depending on model of saw. Only takes a few minutes to play around adjusting and you will get it.
Posted on Nov 30, 2013
4 Suggested Answers
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: can't get chain to tighten
Hello Ted:
This is a very good OM for a Remington. Look at figure 8 on page 8. The adjustment block MUST engage one of the holes in the bar, Then do 1 through 5 as illustrated and you cannot go wrong.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If the block is engaged, the bar nuts are finger tight , and the adjuster will not tighten the chain it must be stripped. If not stripped, follow this example.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If it still causing problems try a local saw shop where someone can see what the problem is. Ask them to demonstrate please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
The chain has come off. I put it back but it is too loose. How do I tighten it
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
May 27, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to tighten a chain on a champion chainsaw
There are some bolts that allow you to extend the bar that the chain runs on. Find them and extend the bar a bit to tighten the chain. Don't forget to tighten them again before you use the chain saw.
Feb 25, 2015 | Garden
After you install bar,chain,and brake cover(tightened)the chain wont turn.
Tighten the adjusting screw with the two nuts loose but snugon the middle of the chain on the top of the bar. Tighten the chain screw until the chain is loose enough to raise the chain up about 1/2 inch then tighten the mounting nuts tight. Then see if it is ok.
Terry
Jan 07, 2015 | Husqvarna 338xpt 14" Gas Chain Saw Husky...
TIGHTEN THE CHAIN
Are you loosing the bar at the same time if yes then lift the bar up and then tighten the chain and then the bar there are some helpful video's on utube
Jul 24, 2014 | Bosch Chainsaw Chain Saw Blade Ake 35...
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
How to tighten a loose chain
To tighten a loose chain you need to pull the cotter key pin from the rear axle then loosen but do not remove the nut. It just has to be loose enough to slide in the swingarm. At this point there are tension adjusters on the ends of the swing arm you tighten them to take the slack out of the chain. NOT TO TIGHT! You should have 1 inch of play in the chain this is up down play not front to back. I push the chain up the highest it can go and measure how far it falls. NOTE: TURN THE TENSION ADJUSTERS THE SAME AMOUNT THE SAME DIRECTION IF THE AXLE IS TWISTED YOU WILL THROW THE CHAIN. This can make for a bad six months!
Aug 19, 2009 | 1998 Suzuki VZ 800 Marauder
49cc kids ATV trouble shooting
in order to tighten your chain you can take a link off which would involve using a grinder, if you dont have one than go to an atv store and ask them to do it. theres a clip on the chain which holds it togther, remove the clip without damaging it than just pop the link off. that will take the chain off. i dont know what type off atv you have so there are probably bolts that hold pull the back end to tighten the chain look for those and if you can find them than tighten them.
for your engine do an oil change and drain out the carborator. if you need more help let me know.
Jun 24, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Loose chain
I had a few chain driven polaris atv's they tension when weight is on the quad, the rear arm pivots and applies tension to the chain , other then that there should just be guides for the chain. If the chain is still loose with operator weight the chain may have play in the pins and need replaced.
May 05, 2009 | Polaris ATV
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
