Question about Toyotomi TAD-30F Portable Air Conditioner
Portable A/C unit will not stay cooling
The unit will not stay cooling when on for a bit it starts to blow hot air
    Master:
  • 571 Answers
Install pressure taps, read the pressure & you will find it is probably low on refrigerant. Find & fix leak...charge as needed.
Posted on Dec 07, 2013
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
Replaced a starter capicator, now it just bloweswarm air
On hot day your unit may not cool enough. Make sure that outside unit is clean, filter inside should be clean. If all above is good your unit may be low on Freon.
Aug 11, 2014 | Dometic Heating & Cooling
My Continental Portable Air Conditioner only blows partially cool air and will not cool my house. I am I just expecting too much? It seems like it needs freon or something like that.
Unless your home is less than 400 square feet, total. You are expecting to much. As the maximum cooling output is only 9800 Btu's These unit's despite being portable, they are only considered as room air conditioners, because of the low Btu output. Any more than 400 and maybe 450 square, it's a struggle for the unit to cool any more than that. It just simply can not do it. Freon ( which has been banded by the EPA) wouldn't help at all.
The best option for you, is to place the unit in a room you spend most of your time in and close the doors to that room, so that it will stay really cool and the AC unit won't struggle.
I'm really sorry. I wish I had better news for you.
Aug 04, 2011 | Continental CE75106 Portable Air...
I want all cold air it blows hot out the back why
the back should blow out hot and at the front it blows out hot
the hot is the air in your room
Jul 22, 2011 | Heating & Cooling
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
No Cooling
The water pump or the float valve is not working.
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Toyotomi TAD-30F Portable Air Conditioner Logo
73 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
