Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Generator won't run
Honda Ex2800c generator won't run for more than 5 seconds. When it shuts down the oil safety light comes on. I made sure there was oil and I'm not on a slant. Still did the same thing. Changed the oil level sensor in the crankcase and added new oil. Still the same problem. Anyone know if the module housing the oil safety light and output light may be suspect? Any ideas?
    Guru:
  • 462 Answers
DId you change the oil filter when you changed the oil I am assuming it has one.
If it has a filter some of them have a check valve in side and this valve may not be operating properly.Also you might try rolling it over a few times with the pressure sensor removed and see if oil spurts out the opening. If so then the problem may be the oil pump not building up oil pressure, or the motor may have a board looking for the oil pressure sensor to close (or open depending on how its engineered) and the sensor board is not working properly or not grounded good. Try cleaning the battery cables just in case (assuming it ahs a battery).
Posted on May 08, 2009
My honda 150cc scooter has a safety device to shut down scooter when out of oil. How do you get the safety device off so scooter will start after oil is filled.? Is there maybe a reset button?
Hi, Sally I missed you yesterday thank God for safety sensors there is a reset button and in the future please include the year and model for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Turn the Oil Change Light off on Honda SH125i
Thread Oil Pressure Light and the Bike Won Start
http://owners.honda.com/assets/OWNERLINK/Model/own_man/powersports/scooter/2009/09_FSC600_A.PDF
http://www.honda-montesa.es/manuales/FES125_150_07.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 15, 2016 | Honda Motorcycles
My honda 2000 generator only runs for about 3 seconds then shuts off
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
Sep 03, 2014 | Honda EU2000IKN EU 2000 Watt Generator 50...
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Honda eu 3000 won't run, cleane bowl,cleaned filter. fresh oil new plug got spark, will run for 10 seconds, the will not crank again. wait 20 min. it like crank an run 10 seconds?
i usually do a quick test of a small few onzes of fuel down the plug hole and reinstal plag and see if i9 fire up and run for a lil bit. maybe 5 -10 seconds. now i know i have spark . most usually our wonderful fuel is the problem. its just nasty now. it can stick a needle to the seat. it can hold her open . one way ya flood out. the other ya starv out. give it a try.
Oct 15, 2012 | Honda 3000 Watt Portable Generator
Generator runs for about 10 minutes and then stops like it is running out of fuel. 5500 NorthStar with Honda motor. Waned fuel tank and lines, had carb. Rebuilt and cleaned all out with carburetor cleaner....
It appears you have eliminated all of the fuel related issues. That would leave the generatoor safety circuits as a possible reason for the unit shutting down.
The Low Oil Level Sensor is the major reason that generators shut down when your sure there is not a fuel supply problem. Make sure the unit is fully servied with OIL. If the problem persists disconnect ONE wire from the low oil level sensor and see if the problem persists. If you still have the problem inspect the black or green wire from the Start run switch all the way to the Air shroud on the engine looking for signs of chaffing.
If you can not find anything then you will have to re-focus your attention on the fuel system once again. If you have a solenoid on the base of the carb.. the solenoid can be WEAK and stop remaining open once hot. This will cause the engine to lean out and die.
You should also check fuel flow to the carb. The flow should fill a spary paint can lid in under 10 seconds to the point your worried about it overflowing. Most honda engines have a metal sediment bowl under the fuel selector. Remove the sediment bowl and dump the contents. Check fuel flow again.
- Carb. With the float bowl removed fuel selector ON check fuel flow again by holding a spray paint can lid under the float. It must fill up in about 10 seconds to the point your worried about over-filling the lid. If you do not have a good flow rate here the float needle float needle rubber seat and the fuel manifold are the prime suspects.
I know this generator has the Honda GX270 engine. Some have solenoids (Item 49 this link)
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE,%20JPN,%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CARBURETOR%20(2)/parts.html
^- No details!
Honda engines by model and VIN can be found here:
http://www.boats.net/parts/search/Honda/Engine/0/parts.html
At this time I think the low oil level sensor (sending uint) may be the culprit causing your problem.
Item 2 this link:
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE%2C%20JPN%2C%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CYLINDER/parts.html
Thanks for choosing FixYa,
Kelly
Sep 16, 2011 | Electrical Supplies
I have a Honda super quiet 6300i generator. It runs fine and then suddenly will stop. It restarts fine and there are no warning lights of any kind lit on the generator. What could be the cause and how...
Check the oil. Many of these units have a safety switch that will shut off the unit if the oil is low. It doesn't take much on some of these. Or, just add a little oil and give it a try, it certainly won't hurt it.
Jul 09, 2011 | Honda Electrical Supplies
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
500 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
