Question about Magellan Se4 GPS Receiver
Magellan se4 hard reset - Magellan Se4 GPS Receiver
3 Suggested Answers
SOURCE: how do I set the time on the Magellan SE4
The default settings on this unit is to use the default time zone. This happens to be set to GMT (Greenwich Mean Time). I changed it to local as follows:
Press the tools icon at bottom of screen off the Menu Press System Press Time Zone Press Use Auto Time Zone to "uncheck" the default setting Press Set Time Zone to get choices Scroll up and down and find a big city in your time zone Select it by touching it I turned off Daylight Savings Time to get mine to set correctly Press the arrow back and you should see your time set correctly now.
Posted on Jan 10, 2010
  • 1196 Answers
SOURCE: My GPS Magellan SE4 say
You will need to reset your device, Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds. This will fix the abnormality.
Posted on Mar 24, 2011
How do I set the time on the Magellan SE4
Dec 03, 2009 | Magellan GPS
It is shutting down while we are using it. it is plugged into the lighter outlet and has power, does not show a low battery
try a hard reset first using a paper clip, innsert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update off the magellan site..you must register the unit with magellan before you can download the update.
Jul 29, 2009 | Magellan RoadMate 1430 GPS Receiver
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
I have a Magellan Maestro 4250 and touch screen not responding
Yes. The hard reset is the little pinhole on the left. Just use a pin and poke it. It should bring everything back to factory default and all saved info, addresses, routes etc. will be deleted.
Jun 07, 2009 | Magellan Maestro 4040 GPS Receiver
My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Needs password
if you got computer software with this unit you might want to reinstall it and reset the password. otherwise you might want to do a hard reset which clears the password and storage memory.
that should help
Jun 12, 2008 | Magellan RoadMate 800 GPS Receiver
Stuck on magellan load screen where it says magellan
there should be a small hole eather in the back or side of the unit to insert a tooth pick or something not share to reset the unit to factory defaults.
that should do it
May 13, 2008 | Magellan RoadMate 800 GPS Receiver
Power Switch for Fantom Lightning
I think that the marking is 5E4, not SE4
Nov 18, 2007 | Fantom Vacums Lighting Canister Vacuum
How to hard reset magellan 700
Hussam.. I believe the newest software upgrade you can get for the 700 is version 4.32 which is the same version used on the 760's. The maps are stored on the hard drive, so I do not think a reset will help but here is how it's done. 1. At the user select menu (first screen to appear after initial turn on) hold down the zoom out key (-) and the repeat button (on top of your unit). 2. Once at the "secret" menu, select reset user data. This will reset all of your personal information from the unit. All of your POI's will be deleted as well as your user name (which you can re-create of course) 3. Your unit will re-boot automatically and that's how you reset your unit. Like I said though, I do not think this will revive your maps. If you have the maps on a DVD-CD then you can reload them that way, otherwise send it to the Fort Worth, Tx repair center and they have the proper program to load data directly to the hard drive. Good luck! -Daniel
Jun 28, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Se4 GPS Receiver Logo
32 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
