Question about Fostoria CH22121C CH InfraRed Electric Utility Heater
2 elements have burned out. - Fostoria CH22121C CH InfraRed Electric Utility Heater
Ge model jkp45 top oven does not heat
Look for the problem in 3 places.
1) the element has burned out.
2) The connector where the element is connected to the wiring has failed, or
3) the wiring has burned in two.
God bless your efforts.
Oct 21, 2017 | GE Ovens
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
My oven does not start
Hello there:
It doesn't work at all dot_lineone.gif 1. No power
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter. Sometimes the power cord disconnects or burns at the appliance, if this is the case, the wiring and the terminal block must be repaired or replaced. ^ top clear.gif Top element doesn't work dot_lineone.gif 1. Top element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#2-1#ixzz1CZ54wKfT
Jan 30, 2011 | Whirlpool Ovens
One of my GE toaster oven's 2 top elements burned out
Hello. It is very difficult finding parts for and appliance over ten years old. I recommend that you shop a bit for a new toaster oven. They are much less costly than they used to be and work better. Plus they have a warranty. J.
Jul 21, 2010 | GE Toaster Ovens
The bottom heating element is not working on my thermador prgs/36
one of 3 things may of happed. 1, the element may have burned out. (you will see a blister or burn through on surface of element. 2 the wires that go to the element may have burned off. 3 the power relay board is not sending power to the element. (bad board or fans sail switch NG)All things need to be checked with 220v power off to the range. I would recomend calling a local pro.
Oct 30, 2009 | Thermador PRG364GLUS Gas Kitchen Range
Burns bread before it can get done. Tried it three times. I am making a 1 1/2 pound loaf of sweet bread. I tried setting it to one pound and light crust but it still burns the bread before it gets done. I...
Look very carefully where the bread pan goes in. There is a heating element around it. If the bread pan is too close or touching the heating element ( the round thing running around the wall), it will burn the bread. You can try moving the bread pan away from the heating element. If you try and bend the heating element, it may break the element, so move the bread pan only.
Apr 11, 2009 | Cuisinart CBK-200 Bread Maker
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Bake Element
There should only be two wires that go to the element. It won't matter which wire goes on which terminal. Turn power off to unit before replacing the element. In some cases when the element burns out and breaks in have it will send a surge back to the oven control board and it will need to be replaced also. You will know once the element is replaced if it doesn't heat up.
Oct 01, 2007 | GE JBP90 Electric Kitchen Range
Burned out element
When the element burned in 2 iot may have tripped your circuit breaker.
Check your breaker box and look for a 40 or 50 amp breaker and flip it off and then back to on. If this doesn't help then a tech. may need to be called for service.
May 05, 2007 | Maytag CWE4800A Electric Single Oven
Fostoria CH22121C CH InfraRed Electric Utility Heater Logo
19 people viewed this question
Top Fostoria Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Fostoria Heating and Cooling Expert? Answer questions, earn points and help others
