Question about Sharp Viewcam VL-Z7U Mini DV Digital Camcorder
I need a Audio/Video/S-Video cable QCNW-B173WJZZ
Why does composite red and white audio need two cables?
For stereo sound you always needed 2 separate cables. White and red. There is no way you could send analog stereo sound on single pair of wires. As for video, yes one pair of cable is enough to carry low quality analog video signal. I wish to see older equipment with stereo audio using single pair of audio cables but there is no such thing.
Mar 03, 2018 | RCA Televison & Video
I lost the av cable that came with my Sharp camcorder purchased in 98. The manual lists the part as QCNW-1448TAZZ, which appears to be unavailable. Any suggestions would be appreciated. thanks
Contact the manufacturer, they may be in a position to help, or at least put you in touch with someone who can. Alternatively, other cables may be available that would suffice.
Dec 21, 2016 | Sharp Video Cameras
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See http://www.svideo.com/scart2.html for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: http://www.retrevo.com/support/Akai-PDP4273M1-TVs-manual/id/741bh140/t/2/ . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Problems with Audio and Video cable
there is a switch on the base of the cable labeled HDTV and TV, move to TV for normal cables.
Dec 06, 2009 | Microsoft Xbox 360 Console
How to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Mar 14, 2009 | Bose 3·2·1 II System
Cable
You mean the system cable part # QCNW-B855WJZZ avalible at www.vancebaldwin.com for about $60.00
Jul 17, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Sharp Viewcam VL-Z7U Mini DV Digital Camcorder Logo
64 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
