Question about Pitney Bowes C180 Copier
Service Manual Canon IR 3035 - Pitney Bowes C180 Copier
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
How do i fix power on paper jam on canon ir 3035 copier?
Probably one of the sensors on the papers way through the machine is out of position,or not working
Mar 05, 2015 | Canon Office Equipment & Supplies
MY CANON IR 3035 START UP PROBLEMS
you are not very clear in you problem but i think that maybe you have to make the firmware first of the copier and than if does not work change the hdd and again firmware.
Oct 31, 2014 | Canon iR3035 Copier
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Service manual Canon ir 2318
Hello friend, I have downloaded a Good canon iR2318 service manual from below link:
Canon iR 2318 2320 2420 2422 service manual:
http://goo.gl/dBXTt0
Good luck on repairs.
Aug 03, 2012 | Canon imageRUNNER 6000 Copier
Canon copier IR 3035 printer port not recon zing in computer
You may need to download or update the drivers.
Drivers are what synchronizes the computer to the printer.
You can download them free from the printer's manufacture's website
Jun 09, 2012 | Office Equipment & Supplies
My canon machine is IR 3035 and having a error code E000001-002 How can I fix this.
this is error code for abnormal temperature rise in fixing section.
You can try to reset error in service mode, but if the problem persist you need to change the fixing film unit.
To reset the error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose: COPIER>FUNCTION>CLEAR>ERR.
Turn off and back on.
Hope that helps!
Aug 22, 2011 | Canon imageRUNNER 3035 Black and White...
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
44 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Victorman
Victorman
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
