Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Picture on picture don't know how to hook it up
I have a samsung 52 " projection televison I do not know to hook up the t.v for the picture on picture it is a older t.v no hdtv on it
    Sergeant:
    Champion:
  • 375 Answers
You require a second video source to select from either tuner or a/v  selection.input
Posted on Oct 28, 2007
6ya staff
SOURCE:
Screen splits in 3 when cable hooked up
sounds like a convergence problem! usually the 2 convergence ICs go bad and the cost for the repair at repair shop is from $200 and up
Nov 10, 2011 | RCA HD52W56 52" Rear Projection HDTV
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Samsung 52" tantus pch521r no picture
1) Loss of color = bad solder connects on signal board
2) Loss of pix = probable CRT coolant leak onto signal board
Have a technician check it out.....can be expensive......T.
Nov 24, 2007 | Samsung PCH521R 52" Rear Projection...
Problem turn on picture few sec. no picture only clear white and sound
I had this problem and replaced the bulb. I have not had the problem since.
Nov 22, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Picture turned pink
This all of the sudden happened if so you may have lost the green alot of times yoiu can fix the CRT drive Brd there is a video amp ic and a resistor that can be replaced or yo can replace the whole Brd a little harder to do than just replacing the parts on the Brd
Oct 17, 2007 | Samsung HC-P5241W 52" Rear Projection...
52" Samsung rear projection TV
Check for CRT coolant leak on PCB's.If minor, clean up spill--try again--see what you have.
Sep 21, 2007 | Samsung PCH521R 52" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
