Question about Whirlpool GS470LEM Gas Kitchen Range
Oven won't maintain temperature - Whirlpool GS470LEM Gas Kitchen Range
My oven is not maintaining temperature
check the door gasket is in good condition.if the door is closing fully properly.check the ground level.
Apr 13, 2014 | Frigidaire Ovens
Electic range oven won't maintain temperature
What is the complete model number of your unit?
Feb 18, 2013 | Kitchen Ranges
LG LRE30451 won't maintain temperature
Check the oven temperature probe (thermister) to see if it is good. To check it, use a multi-meter and Ohm it out. It should be between 1100 and 1600 Ohms. If it is out of tolerance, you will need to replace it. Here is the part to order.
Nov 30, 2012 | LG LRE30451 Electric Kitchen Range
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Whirlpool GS470LEM Gas Kitchen Range Logo
16 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
