Question about Samsung PN51D530A3F
Plasma buzzes screen is cracked,tv turns on but screen is blank and plasma makes a buzzing noise
  • 59 Answers
If the screen is cracked, the set is no longer any good.
Since a screen replacement is usually as much as a new TV, you might as well use your money for a new TV.
Posted on Nov 28, 2013
jerryg50
  • 1667 Answers
SOURCE: 50 " Samsung Plasma TV
Get the tech supplier to tell to the manufacture and the store what he told you.
Physical damage on any electronic device is very hard to have serviced under warranty. I have never seen a plasma display crack on its own. But, anything can happen.
I once saw a man drop a newly bought plasma TV in a parking lot outside from where he bought it and the screen broke. He never even made it home from the store!
Maybe you should contact a lawyer or someone who can give you legal advice about how to proceed with this. In different countries and different states the consumer protection laws are different.
Jerry G.
Posted on Sep 26, 2008
  • 93 Answers
SOURCE: Buzzing sound then dead
Most likely power supply is dead,but there is a small chance that the power cord has been burnt out.If your TV is wall mounted or left very little room behind the tv to allow it to"breath",that could happen.
So,stop by Fry's to get a power cord and replace yours and see if that works or not.If not,it is time for a repairman to do his/her work.You are right,it is not cheap.
Next brand:New Pioneer KURO plasma tv,case closed!Reliable,and top of the line.
solutiondoct
Posted on Nov 06, 2008
dgjtex
  • 405 Answers
SOURCE: Samsung SP-S4243 has a constant buzzing noise
This is most probably you inverter board making the sound, most probably a bad solder joint, It would be hard for me to help you any further, but if it is a bad solder joint it could be repaired. Most shops no longer repair boards they just replace them.
If you have the knowledge you could do this, but I would recommend it other wise, there is High Voltage to deal with. I hope this helps. Merry Christmas!
Posted on Dec 23, 2008
SOURCE: Samsung Plasma has crack on INSIDE of screen- i
WE COULD FILE A CLASS ACTION SUIT IF WE HAVE ENOUGH PEOPLE.
I have created a group so we can join and try to solve this issue, please register at http://groups.yahoo.com/group/against_samsung/join so we can get organized and get a lawyer, I have seen more than 30 people online... hopefully there are even more. Thanks! Suarez
Posted on May 16, 2009
electronick
  • 505 Answers
SOURCE: a buzzing noise coming from inside the tv but
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Posted on Jun 01, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Plasma inner screen cracked, and buzzing. Is it worth fixing the caps?
It sounds like this is an LCD tv - not a plasma.
chances are that if the screen was hit hard enough, at least one of the CCFL bulbs for the backlight broke too. This created a fault in the inverter circuit, cauing a shutdown after a second or two.
Nov 25, 2011 | Televison & Video
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
Jun 01, 2010 | Samsung Televison & Video
42" samsung plasma screen cracking on
i would say take it to your local tv repair shop the screen will have to be replaced or if you told your insurance i happened because of a lighting storm they might have replaced it
Aug 08, 2009 | Vision HDV-42P2 Television
Jerry G.
Sep 26, 2008 | Samsung HPT5054 50 in. HD-Ready Plasma...
SCREEN WENT BLANK,BUZZING NOISE,A CRACK APPEARED ALL AT THE SAME TIME (42 INCH PLASMA)
What brand? Do you see the crack when the set is off? Please advise and I will follow up.
Apr 16, 2008 | Televison & Video
TV EMITTING A BUZZ NOISE
You have a cracked Plasma panel. If u remove the back cover of TV and look in the top left of the plasma panel u will see a small round cylinder tube with glass tip inside. Look with a flashlight and u might see the crack. OH the buzzing noise is from the current going through the panel just not ignition the gases inside the panel to light the phospher cells. Hope this helps.
Apr 15, 2008 | Televison & Video
Samsung PN51D530A3F Logo
178 people viewed this question
Henry  Thomas
Henry Thomas
