CANON S530D PRINTER NO BLACK PRINT ALL OTHER COLORS WORK
STOPPED PRINTING DUE TO PRINT HEAD FAILURE - REPLACED HEAD PRINTER PRINTS HOWEVER DOES NOT PRINT IN BLACK - I INSTALLED A NEW CARTRIDGE WITH THE SAME RESULT - PERFORMED CLEANING AN EXTENSIVE NOZZLE CLEANING ALSO USED THE SUGGESTED ON BOARD (PRINT DEVICE) BUTTONS FOR THE NOZZEL CLEANING TOO WITHOUT ANY CHANGE- ANY SUGGESTIONS
  • 4 more comments
  • Anonymous Nov 20, 2007
    Canon
  • Anonymous Nov 21, 2007
    Same problem. Also, when trying to align the print head I get eleven orange flashes from the leds.
  • Anonymous Dec 20, 2007
    Changed black ink cartridge and prints come out with a greenish/blue color. Performed an alignment. Don't get any color prints either. Both cartridges are full or close to full.
  • Anonymous Feb 19, 2008
    totally no ink purging after replacement of new cartridges
  • Anonymous Oct 25, 2008
    It just stopped printing black even though there was black in the cartridge, but the other colors work. tried cleaning it.
  • summerlender Mar 07, 2009
    same problem here...any solutions?
SOURCE: Printer won't print
If the ink is too low the head cleaning won't work. Also, I have had to do the cleaning functions several times for it to work. Will it print a test page? Look in to reinstalling a print driver.
Posted on Nov 01, 2006
SOURCE: HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Posted on Jan 11, 2008
SOURCE: Canon S530D-Have cleaned nozzles,changed ink
HI,
No I haven't fix the problem. However I've been doing all the cleaning,cleaning and more cleaning. I finally gave myself a x'mas present. I bought a new printhead for the S530D. It's working perfectly now. I was tossing whether to get a new IP4600 or a new head, finally decided on the latter. Simply I can't get after market cartridges for the IP4600. The cartridges for the IP were way too expensive at this moment and not knowing whether the claims for the print numbers are accurate. Perhaps readers may be able to collaborate the claims for the IP4600 or IP4500.
Regards and seasons greetings & a happy new year 2009,
yuen yoon
Posted on Dec 27, 2008
tigertail
  • 163 Answers
SOURCE: Black ink nozzle clogged
If you have tried 5 or 6 head cleans, left for about 10 hours and then tried 3 or 4 more without noticeable result then you probably need a head cleaning solution. Google for stockist near your area or try this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Hope this helps. Please take a moment to rate this solution, thanks.
Posted on Mar 25, 2009
  • 739 Answers
SOURCE: nozzels clogged from lack of use. Bought new ink
As it's an Epson the best thing to do is chuck it and buy something new.
Epson printers are notorious for this if they have not been used regularly. as the print head is actually part of the printer and not something to can replaced like it is with a Canon or HP the entire unit has to go back to Epson to be cleaned.
I know many people, professionals included, who have given u pon Epsons for this very reason.
Posted on Dec 21, 2009
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have set the Canon MP560 printer to print grayscale (black and white) but it still uses the color cartidges, apparently to periodically clean the nozzles so they will be able to print when needed. So I...
Canon has made there printer this way to SAVE on your black in and also to lubricate the print heads and other technical reasons.
To be honest I do not think its in your best interest to override the settings on this print due to the cause of damage to the print head and other sorts of failure.
There are chip re setters and other forms of ways to trick the system, These Void the warranty and thus Canon does not allow for this type of compromise to save ink. the best thing you can do here is purchase a ink kit with a chip that uses a contentious flo system to save you on ink purchases and money.
Here is a link to a example http://www.amazon.com/FantasyBuy-Bulk-Continuous-Ink-System/dp/B002T046TU
Good luck with your printer I hope this is a solution that best suites your needs to save money.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 30, 2010 | Canon Office Equipment & Supplies
I've got a Canon Pixma MP 500. Printing from my computer = faded print. Copying = blank page. Auto head align fails. Alarm light goes on. Have tried stop/reset button. How can I fix this?
It sounds like the print head on your printer is either clogged or not working.
You get faint print from your computer because the computer will use your color inks to get gray. When you copy, it only tries to use black and the black isn't printing at all.
Check your user's manual and it should show you how to clean the print head. Otherwise replace the print heads and you should be fine.
Thanks,
Pat
Aug 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
Only black!
The printer require print head repalcement.
Apr 18, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
478 people viewed this question
k24674
Marvin
Marvin
