Mini split problems
Hi, I'm having problems with my Coaire mini split system. It's been freezing up and spraying water, and at times ice cubes, from the indoor unit. This' often accompanied by a loud grinding noise. Also, the line-set, where it connects to the compressor, will freeze, and there's often a small pool of water underneath. Was hoping someone might be able to tell me what's going on with this thing. Just had it installed recently, and it's been doing this ever since. Thanks for your time.
  • 3 Answers
One check your indoor fan is correctly running ( blowing a good quantity of air. Two look for oily residue around flare connectors indoor and outdoor usually indoor first. This indicates a leak. Thus why the ice . Good luck
Posted on Nov 27, 2013
  • 4 more comments
  • Ben Nye
    Ben Nye Nov 27, 2013
    Thanks for the reply Dane-1,
  • Ben Nye
    I'll check the line ends for leakage as soon as I get home. These are the do-it-yourself threaded ends which FWIU have a tendency to leak..
  • Ben Nye
    Is it normal for my line-set to collect condensation? The guy that installed it made a mess out of the insulation around the line-set, lots of tears and whatnot.
  • Ben Nye
    Haven't noticed any issues with the fan, but I'll check that as well.
  • Ben Nye
    Ben Nye Nov 29, 2013
    As far as I can tell the fan's working fine. I can't really access the back of the wall unit to check the connection. The whole thing's wrapped up with tape, oily and dripping wet. I can't feel anything oily on the other end of the line where it connects to the compressor, but all the exposed copper line at that end has been completely covered in ice.
  • Dane-1 Nov 30, 2013
    Just cut a slit in the tape , where it meets the insulation the two flare nuts will be underneath , normally the larger of two pipes will be loose or poorly flared. If it\'s oily you will need to repair leak and recharge with refrigerant. Cheers Dane
4 Suggested Answers
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: Senville Mini Split Error Code
The E4 light on your system is saying there is a commiuntion problem between the inside unit and the outside heatpump unit.Make sure there are no loose wires and you wired it properly,The S wire is the commiuntion link wire make sure it is a solid run between both units.I had the same problem with my system and it was the s wire not making a good connection.
Posted on Apr 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
Hi, warning light on the central display of the indoor unit Coair A/c mini split blinks continuously, and unit does not respond to on/off. What is the reason and how to solve this problem
Try unplugging for 30 minutes and plugging back in. Make sure remote has fresh batteries, make sure timer setting for proper time is accurate. A power source running nearby may cause this unit to malfunction. If you don't have auto start, all you should have to do is press the remote 'on' button once power is restored. Here is a link to your manual. http://media.hydroponics.net/item-documents/coaire/coaire_UserGuide-1.pdf
Apr 02, 2015 | Heating & Cooling
Ice hitting outside fan
It sounds like your system might be low on coolant. Check the pressure of the main line and check it against the specs. You may have a leak in the system.
Mar 02, 2015 | Rheem 12,000 BTU Mitsubishi 13 SEER R-410A...
Hi there my ice maker on a whirlpool model#ED25PQ,is making ice but the cubes are clearer looking than in the past also when water fills in to make new cubes it sprays all over refrigerator and water goes...
A) If water sprays like you say then there might be air trap on the line.
b) But most likely your Ice maker fill valve me be not closing and overflowing and creating the freezing mess.
Feb 14, 2015 | Whirlpool Refrigerators
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
Water is leaking into the ice tray freezing all the ice cubes together
That maybe it or it may be your preception, If the heater in defrost is over heating during the defrost cycle you can get the same results
Dec 17, 2017 | KitchenAid Superba KSRG25FK Side by Side...
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
