Question about Kitchen Ranges
Blades removing from a masport garden gobbler
3 Suggested Answers
backwoodsctr
  • 169 Answers
SOURCE: Blades on Masport Ride-on won't disengage.
Yes sir assuming that all parts are origional. 9 times out of 10 its a rusted up idler arm. Remove the rust and grease up the idler arm bushings. Lubricate all other pivot points with machine oil or wd40.
Posted on Nov 22, 2009
  • 1116 Answers
SOURCE: how to remove the blade from the Masport lawn
There is a nut in the center of the blades. The easiest way to remove this nut is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock the blade from from turning and you will need a long handle ratchet in order to give enough torque to remove the nut. Once the nut is removed, the blade will slide right off. If you are doing this to sharpen the blades, you do not need to remove the blade to do this. Use a 1/2 HP grinder wheel and just evenly slide the wheel down the blade until it is sharp. CAUTION: it will cut you finger. Make sure you disconnect the power and the fuel is turned off at the time you do any of this work....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
How to remove four blade base plate from masport 450 series
use hole where bolt for blade goes insert a large screwdriver or steel rod and get it to catch on the casting or at the grass throw end with base locked you can now undo lock nut. should be lefty loosy.
Feb 26, 2017 | Cars & Trucks
Masport series 20 mowing uneven
check /replace blades
level up the mower deck
the blades have to be parallel to the ground so if wheels are worn or the deck tilts in any direction the cut will be uneven
Feb 03, 2017 | Garden
I have had my Masport mower serviced plus new blade but it dose not cut the grass
What is the problem?? Is there not enough power or does it run okay but just not cut the grass in which case maybe the blade in upside down.
Oct 12, 2014 | Garden
Masport mower
few things to check fuel lines are connected properly one may have gotton losse offf or pinched then make sure the blades are in off position some its a lever or a pull/push switch and battery may have gone dead or distributor to spark or plugs
Apr 13, 2014 | Garden
How to remove the blade from the Masport lawn mower
Jun 09, 2011 | Garden
G'day, I have just used my masport 1000 presidential for the second time since purchase and it is not cutting the grass. It was cutting well initially until I emptied the catcher and made a height...
I have just found out that your mower has the Unique Quickcut blade system, with swingback feature to protect the crankshaft from damage should the
mower strike a solid object. If you can, you should check this and make sure this feature is operating correctly. It sounds like it has maybe malfunctioned, thus the cutting problem.
Feb 06, 2011 | Garden
I have a masport ride on mower i need to find out how the final drive works or even a diagram
Get in contact with Sullivans Garden Machinery, bristol, uk they are a main masport dealer and should be able to help you their contact infomation can be found on their website http://www.sullivansgardenmachinery.co.uk
Sep 19, 2010 | Garden
Fitting a drive belt on a Masport 155/106 ride-on mower?
I am having troubles finding my model number for a 155/106 so I can get parts for it
Dec 14, 2009 | Garden
Nov 21, 2009 | Garden
Kitchen Ranges Logo
140 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
