Question about Bosch B22CS50SNS Side by Side Refrigerator
Freezer not cooling after self test done
Yesterday our fridge alarm sounded. This often happens even though we thought we had closed the door(s) properly. Yesterday we left the house around 8:30 AM and no alarm was sounding. When we returned at 3:00 PM the alarm was sounding so we opened and reclosed the freezer/fridge doors. This morning we ran the appliance self test as described in the fridge manual on page 26. It did not result in displaying and "E" for error nor did it indicate any fault. At the end of the test the display showed that the inner temperature had reached 3 deg. How do we get the freezer to work properly?
SOURCE: What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Posted on Jan 04, 2008
22yooper
  • 828 Answers
SOURCE: When I come home the
Could be warning you that the condenser coil is in need of cleaning. Under front by toe plate or in the back under fiber cover. Vacuum out all dust and make sure the air circulation fan is running when the compressor is in operation.
Posted on May 15, 2008
22yooper
  • 828 Answers
SOURCE: The alarm on my fridge
It may be warning you that maintenance is in need. Check and clean your condenser coils . Under in front behind toe plate or in back behind removable fiber panel. Make sure the panel is replaced after you clean the condenser.
  • 19 Answers
SOURCE: Bosch classixx fridge freezer. Freezer
Defrost fridge, remove product from freezer and store temporarily in another freezer, defrost at least o/night, then try again.
Posted on Nov 13, 2008
projdoc
  • 2237 Answers
SOURCE: Bosch Fridge Freezer (about 12 years old) has
the main board is most likely bad.
Posted on Nov 13, 2009
My ctf1826ar freezer works great but the fridge is not cooling. Nothing is frozen or blocked. When the freezer door is open there is cool air that comes our of the vents in the fridge but when it is...
the frig part not cooling though the freezer works is usually caused by bad air flow due to restriction somewhere. check ur vent settings and make sure not defective, the door rubber insulation may also be defective and not sealing properly after closing? and thus cool air escapes? but if ur feeling noticing air flow from the freezer but not in the fridge, the flow is obstructed, if the flow is off and on, do u notice the sound of the fan always running or does it go off and then on, it may be defective, the only time fan should go off is when in defrost mode?
Sep 27, 2014 | Refrigerators
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
The top section of my refridgerator is not cooling at all and the alarm goes off constantly even though the door is cloased what can be the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | AEG Santo 3888 KG8 Bottom Freezer...
I have a Kenmore fridge with the freezer on the bottom model # 52600. What is happening is the fridge is not cooling but the freezer works.If you have any suggestion please e-mail me. thanks
if the freezer is ok,the damper of the ref side is close need to adjust or replace,2 is the sensor is the sensor is defective the ref side not cooling even the sensor of freezer side if defective may cause why not cooling in ref side,its hard explain to remove or to check the unit by its your self,much better call an service technician to check what the exactly coz why not cooling,and you get a warranty for the service compare you buy a part,but you dont know what how to test the part if is ok or not.
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have LG Bottom Freezer Refrigerator for 5 years. I noticed that yesterday that a funny motor sound came from the back of the refrigerator. When I open the refrigerator or freezer door, the sound would...
The problem could be a bad bearing in the condenser or evaporator fans...more likely though is that the evaporator fan is hitting an ice build up on the coils...this can be caused by a bad defrost timer...
more closely check on the sound... you will find it....
a few drops of oil on the fan shafts just ahead of the motor will not hurt either...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Aug 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Bosch B22CS50SNS Side by Side Refrigerator Logo
54 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
