Can I use 3300uf 10v caps to replace a 2200uf 10v cap. The size seem not to be an issue. Will this harn the tv in any way?
SOURCE: i have a philips 42"
did you replaced the caps correct? ( + tot + and - to - )
Check if the removed cables were placed back correct.
SOURCE: Will not show picture, I get blue lines across the screen.
Just make sure you keep the values the same. Don't use underated caps and yes change those 4 caps. If you keep the same rating the caps should be the same size. Nichicon has always been a sorry cap. Try to get different brands if possible.
SOURCE: i have a westinghouse sk19h210s will not turn on.
their right volt rate will not matter as long as it is higher do you have any other indecation of the unit getting power? if not check you fuses if so you mainboard could be your problem check carfully for more bad caps
