Question about Freezers
I can not help Tina Swan on farm ville 2
I't won't let me go to her farm to help.
I HAVE A SWAN SR4150W CHEST FREEZER A ND I HAVE JUST PUT IT ON AFTER A YEAR THE RED ALARM LIGHT IS ON IS THIS JUST UNTIL IT REACHES THE RIGHT TEMPETURE
Most freezers have a red neon light on the door to indicate if there is a loss of power, so that you can mitigate food loss before you call a service co.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 20, 2017 | Swan Freezers
Water filter won't turn
please try it according to filter catalogue.
Mar 02, 2013 | Maytag Amana / UKF8001AXX Swift Water...
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
Feb 13, 2013 | Kenmore 5 cu. ft. / 142 liter Upright...
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
My kenmore elite undercounted ice maker keeps blowing the reset button the outlet located on the wall nearby. We hadnt had an issue with the reset button prior to a recent repair made to motor and...
Maybe there was something bumped or overlooked during the cleaning/repair process like a cooling fan?
Did you add any other appliances to that circuit before/after/during the repair to increase amperage draw on the breaker?
Try replacing the overload protection outlet with a new one as it may be faulty/worn out. Good luck
Jul 20, 2011 | Kenmore Freezers
I am looking for the instruction manual to my lost freezer SWAN SR5030
If you lost the freezer, why do you need the manual?
Swan is a UK company that does not have a website for their freezers. The UK help center phone number for Swan is: SWAN helpline: 0845 610 4118
email: sales@swan-brand.co.uk
Also, isn't a freezer a little large and hard to loose?
Feb 01, 2011 | Freezers
The 2 fans are not working but the freezer coils are freezing up won;t go below 20 degrees
the freezing is and temp are caused by the fans not working. One fan pulls warm air out of the box and across the evaporator coil, which in your case is frozen, and the other fan is used to pull air over the condensing coil which rejects the heat pulled out of the box. check the wiring diagram for a fan relay first, which can easily be changed out, or by some crazy chance, both fans quite working at the same time
Nov 20, 2009 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
