Question about Vizio E3D470VX 47 in. 3D LCD HDTV
Replace ir board - Vizio E3D470VX 47 in. 3D LCD HDTV
Are sceptre x505bv-fmdr and x505bv-fmqr circuit boards interchangeable?
Sceptre X505BV IR Sensor Board Please Read The Note ...
www.ebay.com > ... > TV Boards, Parts & Components eBayThey are not interchangeable. ... Sceptre X505BV IR Sensor Board - Please Read the Note C2050C .... $6.89 Buy It Now or Best offer Free shipping; Sceptre X505BV-FMQRIR Sensor Board $6.89 ... Sceptre X505BV-FMDR, IR. ..... For Samsung Galaxy Note II,; Cell Phone Printed Circuit Board For Samsung Galaxy Note ...
Sceptre X505BV All in One IR Sensor Board 142011100011 ...
eBaySceptre X505BV All In One IR Sensor Board - 142011100011 - Please Read the Note in ... offer Free shipping; Sceptre X505BV-FMDR IR Sensor Board 142011100011 ...Sceptre X505BV-FMQR IR Sensor Board. ... They are not interchangeable. .... PrintedCircuit Board for Galaxy Note 3,; Printed Circuit Board for Samsung ...
Dec 26, 2015 | Sceptre Televison & Video
Why wont the remote control feature work on my Panasonic TCP50UT50 Plasma, is there a feature to disable the remote, panel works well
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 21, 2015 | Panasonic Televison & Video
IR board location
Hey Tony,
The IR board will be on the inside of either the bottom center, left, or right of the front bezel.
Apr 03, 2013 | Samsung LN46A630 LCD TV
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Feb 09, 2013 | Vizio Televison & Video
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
I have a Sony Bravia LCD TV. The model # KDL 32L5000. The remote for some reason just stopped working. Well i have tried multiple universal remotes and still never worked. The buttons on the side of...
Welcome to the world of Sony **** Bravia and their **** customer service. You will find this is a HEAVILY reported problem and Sony will gladly ignore it and expect you to cough up $200 to trade out a 2 year old TV. Yes, it is the IR board. Yes, I will never buy another anything Sony.
Jun 28, 2011 | Televison & Video
37lg30 will not turn on w/ factory remote or any other remote programmed to TV. Already tried the obvious solutions - batteries, unplug to reset, etc. Once you turn on the TV manully non of the functions...
I'd check out the IR board on your tv. If you have electronics experience open up th etv find the IR board - trace it back to the AV board make sure all connections are plugged in good then if that doesnt work I'd replace the IR board first. That would be the cheapest part to replace. Also it could be the IR on the remote - but if the codes you used to program the programmable remote are known good for your model i'd look at the tv first.
thanks,
michael
Apr 16, 2011 | LG 37LG30 37 in. LCD HDTV
Hi I recently change the main board of my protron 32"pltv television and my remote control does not work anymore, do I need to change the IR remote receiver
You will need the scope to find out if the IR receiver is putting out the signal to the main board, or take a chance by replacing the IR board. Did the remote work before changing the main board?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 12, 2010 | Protron PLTV-32 Television
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
Vizio E3D470VX 47 in. 3D LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
