Question about RTO Automatic Transmission And Engine Oil Pressure Tester
95 oldsmobile cutlass ciera leaking transmission fluid around the oil pan
Coould this be my transmission cooler lines it leaks alot
    Genius:
  • 1,198 Answers
Have the car put up on a lift, or over a pit for inspection.
Posted on Nov 28, 2013
Car is dumping oil at front making a sqealing noise like its an oil pump
first check fluid levels --power steering--oil--transmission --if power steering low or out pump will sequel look for blown hose or seal----if oil is low or empty than look under around oil filter [hole damaged or blown gasket ] spraying on belt causing sequel if not filter than trace oil leak possible oil pan damaged or gasket crack or head or valve gasket-----if trans low or empty look at pan- gasket ,or damaged check trans cooling lines to radiator-----these are your leak areas under hood your oil pump is internal in oil pan and you usually dont hear it
May 16, 2014 | 1997 Oldsmobile Cutlass Supreme
Transmission slips in d &od with steam in cab
transmission slipping could be low transmission fluid level or need a transmission fluid and filter change.if transmission fluid was real low check for transmission fluid leaks around transmission oil pan gasket or fluid leaks around cooler lines or torque converter shaft seal. if you getting steam inside cab.your heater core is leaking.if transmission fluid level okay and filter been changed could have faulty over drive switch.
Dec 18, 2012 | 1998 Chevrolet Blazer
1989 Oldsmobile Cutlass Ciera leaks oil on back side of motor. Where are the possible locations of this leak?
that all depends on how high the leak comes from, it could be from the intake manifold gasket if its high up on the motor,, a little lower would be around the bearing seals , and lower yet could be the pan gaskets ,, keep in mind that a lot of wind is generated when the motor is running at high speed, and a leak from the front of the motor could be blown to the back very easily.
Oct 07, 2011 | 1989 Oldsmobile Cutlass Ciera
Leaking transmission fluid
TRANSMISSION FLUID LEAKS,CAN BE FOUND AROUND PAN GASKET.CHECK PAN GASKET,IF IT LOOKS WET AND YOU SEE FLUID DRIPPING AROUND THE EDGE OF OIL PAN, REPLACE PAN GASKET, WHILE YOU REPLACING PAN GASKET REPLACE TRANSMISSION FILTER WHILE OIL PAN OFF.IF TRANSMISSION OIL PAN NOT LEAKING, CHECK TRANSMISSION OIL COOLER LINES GOING INTO RADIATOR YOU WILL LOOSE A LOT OF FLUID THERE ALSO TORQUE SHAFT SEAL WILL CAUSE HEAVY FLUID LEAK WHILE ENGINE RUNNING CHECK OIL COOLER LINES AND LOOK AT THE TORQUE AREA WHILE ENGINE RUNNING YOU WILL SEE FLUID POURING WHILE ENGINE RUNNING THE OIL PUMP PRESSURE WILL PUSH FLUID OUT AT THE LEAKING AREAS.
Aug 01, 2011 | 1991 Nissan Stanza
I have a 2000 beetle turbo and just notices it is leaking oil from around the plug which is tight and seeping transmission fluid. Is this going to be a costly fix?
OIL LEAK AROUND THE SPARKS PLUGS COULD BE LEAKING VALVE COVER GASKETS ALLOWING OIL TO SEEP BY GASKET FLOW DOWN AROUND SPARK PLUGS.TRANSMISSION LEAK IS NOT VERY EXPENSIVE LONG AS TORQUE CONVERTER SHAFT SEAL NOT LEAKING WHICH TRANSMISSION HAS TO DROPPED OUT TO REPLACE SHAFT SEAL.IF TRANSMISSION LEAK AROUND FRONT AXLE SEAL IT MAY COST A LITTLE.BUT PAN GASKET LEAK OR OIL COOLER LINES WONT COST TOO MUCH NOT HARD TO GET TO REPAIR.PHONE AROUND GET PRICE CHECKS.
Mar 24, 2011 | 2000 Volkswagen Beetle
How do you replace the transmission cooler on my 89 oldsmobile cutlass supream
Your trans cooler is located inside one of the radiator tanks and would be expensive to replace.
You can either replace the radiator with new or used or cut the lines and install an external cooler as is used for towing. If the cooler in the radiator is leaking, you need to flush the system to remove as much oil as possible or it will cause hoses to soften and fail. Also wise to change trans fluid as well.
Always use double clamps when running rubber lines for cooler so they don't slide apart under pressure.
Feb 14, 2011 | 1989 Oldsmobile Cutlass Supreme
Leaky transmission fluid
CHECK UNDER VECHICLE IF TRANSMISSION FLUID UNDER TRANSMISSION MORE LIKELY PAN GASKET LEAKING FLUID.IF FLUID HAS NOT BEEN CHANGED THE PAN GASKET GET HARD LEAKS FLUID.THATS IF YOU HAVE SLOW LEAK.IF YOU LOSING LOTS OF TRANSMISSION FLUID ITS .LEAKING AT TORQUE CONVERTER SHAFT SEAL.LEAKING AT COOLER LINES.CHECK COOLER LINES FROM RADIATOR TO UNDER CAR WHERE COOLER LINES GOES TO TRANSMISSION. AND CHECK LEAKS AT FRONT DRIVE SHAFT AXLES SEALS
Jan 25, 2011 | 2001 Saab 9-3
Does the transmision pan have a drain plug?
Sorry but no, you have to remove the pan to drain the transmission, or you can remove the return transmission cooler line and slide a hose over the line and put the other end in a bucket and start the engine this will let the transmission pump the fluid out........HAVE FUN
Nov 30, 2010 | 1996 Oldsmobile Cutlass Ciera
Leaky transmission fluid. possible reasons?
TRANSMISSION LEAKS COME FROM TRANSMISSION OIL PAN GASKET LEAKING.OIL COOLERS LINES LEAKING.LEAKING AT TORQUE CONVERTER FRONT SEAL.TRANSMISSION SPEED SENSOR SEAL LEAKING.FRONT AXLE SEALS LEAKING AND LEAKING AT TRANSMISSION COOLING LINES TO RADIATOR.CHECK ALL YOU WILL FIND LEAK.IF YOU HAVE FAST LEAK OR PRESSURE LEAK.WITH CAR RUNNING IN PARK EMERGENCY BRAKE APPLIED LOOK UNDER CAR IF YOU SEE FLUID LEAKING OUT IN LARGE QUANITIES.COOLER LINES LEAKING OR TORQUE CONVERTER FRONT SEAL LEAKING.IF YOU HAVE SLOW LEAK THE LEAKS HAS TO BE AXLES SEALS OR PAN GASKET LEAKING OR VSS SENSOR SEAL LEAKING.
Aug 03, 2010 | 1998 Pontiac Bonneville
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
53 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
