Question about GE Profile PFSF6PK Bottom Freezer French Door Refrigerator
GE FRENCH DOOR REFRIGERATOR DOES NOT MAKE ICE
    Top Expert:
  • GE Master
  • 12,962 Answers
First thing to check is if the freezer temperature is going down low enough for the ice maker to work - around 10 degrees. The icemaker thermostat will not activate the mechanism (cam motor) unless this requirement is met.
Posted on Nov 28, 2013
SOURCE: ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
SOURCE: GE Profile Refrigerator door latch broken
I need a door latch for a 1932 GE refrigerator
Posted on Apr 25, 2011
How to get ice maker to make ice.....?
check the tubing that supplies water .relocate as needed
Apr 26, 2015 | GE Refrigerators
GE french door bottom freezer will not make ice
HI.DIFFICULT WITHOUT A VISUAL.BUT TRY MANUALLY PUTTING SOME WATER ON THE ICE TRAY AND TRY.IF ICE DROPS ONCE THEN IT COULD BE THE VALVE BRAKE IN THE LINE OR THE ICE MACHINE ITSELF GOOD LUCK ALI
Jul 12, 2012 | GE GFSS2HCYSS 22.0 Cu. Ft. Stainless Steel...
To much ice
IS THERE A BAR ON THE I/M IF THERE IS NOT ONE INSTALLED ON IT THERES NO WAY FOR I/M TO KNOW TO SHUT OFF AND MAKE ICE
Jun 04, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Jan 05, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
Our GE Profile Ice maker is not making ice,and water is not cold?
heatman101
Aug 24, 2010 | GE Profile PFS22MBS Bottom Freezer French...
My GE ice maker has forzen up with too much ice & wont eject
Unplug refrigerator, remove frozen food and use a hair dryer on the ice to remove it. Thanks, Sea Breeze
Feb 08, 2009 | GE Profile Stainless Bottom-Freezer...
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
Lights are on controls on not cooling
hi thanks for the question Your fridge is stuck in defrost cycle replace defrost timer. THanks for the Question The appliance doc
Sep 12, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE Profile PFSF6PK Bottom Freezer French Door Refrigerator Logo
188 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
