Question about EdgeStar CWR361FD - 36 Bottle Built-In Dual Zone French Door Wine Cooler - Black/Stainless Steel
Just purchased and is not cooling at all
Temp has been set to 55 on each side, but cooler stays at room temp.
    Top Expert:
  • 12,223 Answers
Please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Posted on Nov 28, 2013
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
Jun 02, 2011 | Danby DWC283BLS Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
The temperature icon does not light up so you can read the numbers. I can't set it on the correct temperature. It keeps gong back to 70.
when you are setting the temp the display shows the set value .. but when you release the buttons for a few seconds the display reverts back to the actual temp inside .. so if you set it at 55 deg F .. after a second or so it will jump back to 70 or whatever it happens to be at that time inside the cabnet .. eventually it should go down to your set point (several hours) .. but mine didnt .. it stayed at the room temp forever .. the fan was running but the solid state cooling device actually had no power (requires about 4 amps at 12 volts).... the problem was a blown fuse in the power supply inside the cabnet .. make sure the unit is not plugged in if you are going to take the back off the machine ... in my case all that was needed was to replace the primary side fuse (about 2 or 3 amps i think) there wasnt but there could have been other problems as well .. the power supply is what they call an "off line switcher" when it is plugged in it has dangerous voltage and current levels .. so again dont plug it in unless it is assembled in a safe manor ..
the same power supply might power the "back light" for your display ..
Jul 13, 2009 | Oster 12-Bottle Wine Cellar - Black
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Whirlpool not cooling properly
I would expect the defrost timer to stay in defrost 21 minutes. IT seems your timer is normal.
If turning the ref section temp colder made compressor come on, it could be that the thermostat is worn a little and just needs to stay on a little cooler setting. Check the freezer temp dial and It should be at just slightly more than 1/2 of available setting. If there is A B C you would want to be a little cooler than B about B and 1/4.
I hope this helps K S
Nov 22, 2007 | Refrigerators
EdgeStar CWR361FD - 36 Bottle Built-In Dual Zone French Door Wine Cooler - Black/Stainless Steel Logo
258 people viewed this question
Top EdgeStar Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you an EdgeStar Furniture Expert? Answer questions, earn points and help others
