Transferring info from one hard drive to another
Hi there!
My name is Brigitte and I don't have a problem, i just want to know if  my way of transferring info from one hard drive to another will work.
I have an old HP pavillion that still woks pretty good. It is running Windows XP and I like it. All I want is to add a larger hard drive for my dvd files.
I remember that with the old floppy disks if you wanted to copy one to another it was a pretty straightforward drag and drop.
I have an expansion bay for an additional hard drive, EIDE connection. Once I install the new hard drive, I'll have two--the small one and the larger one. Can I drag and drop the entire contents of the old hard drive onto the new one without a problem?
Also, how do I get the computer to boot up from the new drive once the data is transferred?
  • 1 more comment
  • Amustech Nov 03, 2007
    Primary boot drive is going bad. Need to transfer boot-up to the newer drive.
  • Anonymous Dec 03, 2007
    I've transfered, my old drive (C:\), to (F:\), a new 160 Gig Firelite external drive. How do I make the new Firelite bootable, or is it already bootable leaving me to only change the boot sequence so the Firlite goes first ?
    Hope that made sense.
    Thanks..Mike
  • simmo70 Jul 29, 2008
    can I drag and drop one hard drive to another
Ghost 12 made my CD ROM disapear it messed up the lower & upper filters in my registry I do not recomend it.
Posted on Sep 12, 2008
Hi i just want to know what the jumper seting are [email protected]
Posted on May 19, 2008
Thanks. I was afraid of that; not as easy as I'd hoped. I've made two backups of the old drive, C:\XP OS,SATA 60Gig, to the new Blank Firelite,SATA 160 Gig drive using the boxed FireLite software. Then insatlled Vista over the old C:\XP OS above. Second I did a Clean install of Vista Primium to a new 320Gig installed as C: with Ghost 12.0. My hope was to write some boot sector data to the 160 and 320 dirves and have 2 extra bootable drives. Obviously, I should read more before writing. My apologies. ..Mike
Posted on Dec 03, 2007
    Scholar:
  • 116 Answers
No that wont work.  :)
You will never be able to copy all the files from windows.
Here is my suggestion.
Their are several programs out their to help you accomplish a disk to disk copy. I personally use Norton Ghost. Action True image is another.
This particular program i have found extremely reliable.is Norton Ghost 2003. This is a hard drive cloning software that runs from dos.
When you are running windows, you cant copy by drag and drop, all the files. Windows just wont let you move the important files.
You could purchase norton ghost 2007. That software is designed to work from windows. You can install it and then clone the running drive onto the new fresh drive.
After you clone the drive, you can just set it to "active" and switch the boot order in the bios. Or just unplug the old drive.
I can assist you in getting a copy of norton ghost dos edition, and clone the drive. However it would require direct connection to your pc, and phone support to walk you threw it once your into dos.
Posted on Oct 11, 2007
  • 101 Answers
You CAN drag and drop files between drives, just like you did with the floppy drive.  You can't copy the O/S with drag and drop though.  if you have an O/S installed on both, plug the IDE1 cable to the one you want to use to boot.
SOURCE:
I need an Iomega external hard drive 1GB That is USB 2.0 and 3.0 compatible. I don't know if the dual ones come in portable ones. Need the names of any of their models that would fit my needs....
I don't know the names of any of their models but if you buy one that is USB 3.0 compatible, you will be fine. USB ports are always backwards compatible so buy a 3 and it will work fine on a 2.
Semper Fi,
Z
Jan 01, 2018 | Computers & Internet
I am trying to back up and then download my pictures and documents from my desktop (VAIO) whitch has crashed I need to know the steps in retreiveing all info off of my motherboard and add it all onto my...
Hi Eva, I already answered other of your questions, and if your hard drive is still working, you can use an USB/SATA/IDE adapter so you can use it as an external hard drive, and then you can browse in to your hard drive to find all you info (C:\users\your name\documents), and then copy it in to your laptop.
Sep 27, 2012 | Sony VAIO PCV-W600G PC Desktop
Cannot transfer files from usb to hard drive but ok other way
Since you did not mentioned how many files or how big is the files you are transferring I will just assume you are transferring several files or several folders. You best shot is to transfer files by batch or transfer it little by little. This way you will know which of the files are not transferring to your hard drive. Please note get all the files that are not giving errors. After doing that you need to scan your USB for errors.
If your Operating system is WINDOW 7 / windows xp
- Go to my computer
- Right click the USB drive then properties
- Click Tool tab
- Then Click check now
- After that try copying the files again.
Sep 10, 2011 | Computers & Internet
I just purchased a WD my book essential at Costco. I have an IMAC and need to reformat. I have Snow Leopard and plan on getting the new Lion after I transfer information to the haard disk. I just...
How do I format the external hard drive on a Macintosh computer?
To format the drive for MAC OSX
1. Connect the drive to your computer.
2. Open Disk Utility. (Applications folder > Utilities folder > Disk Utility). Select the hard drive in the left hand column and click on the Erase tab.
3. In the Volume Format drop-down menu, select Mac OS Extended *.
4. Once you have selected the format and have named the drive, click on Erase. You will be presented with a 'Are you Sure' dialog.
5. The drive will format and upon completion will be available for use.
Note: * For the best performance, we recommend using Mac OS Extended format. However, if you will be transferring files between a Windows system and a Macintosh, format the drive as MS-DOS (FAT32) or use a program such as MediFour
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 20, 2011 | Western Digital My Book Essential Edition...
Hi, I am having problems transferring files from my macbook pro(never had this problem its like its locked out my laptop) to the hard drive it keeps telling me "The item cannot be moved because LaCie...
Yup because you formatted in NTFS yesterday on your friend's windows. only window pc's can write to the hard drive.
so you will need to reformat it under mac to mac extended.
or if you want to FAT if you want to write from both platforms.
please note that FAT file size is limited to 4GB's..
you could download NTFS write drivers for mac but it is unsafe and data can be corrupted.
Mar 11, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 22, 2010 | Philips Computers & Internet
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Regards.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
Transferring info to sanDisk 1GB
Did you eject it through the software or pulled it out of the USB
This is very common the flash drive recommends that you do this so that your data is saved
(please feel free to leave a rating)
Aug 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Replacing hard drive
Hello frank you can get info of how to change your apple g3ibook on various website like www.eserviceinfo.com and many other by searching on google and by typing the ibookseries followed by free manual or visite www.apple.com for more info
Jan 15, 2007 | Apple 12" iBook G3 700Mhz with 256 RAM,...
Open Questions:
Computers & Internet Logo
510 people viewed this question
Ekse
Alun Cox
