Question about Garmin nuvi 255W GPS Receiver
Display went blank to the calibration screen while traveling
Was traveling with the 255w on, the display froze and would not change as I was driving, turned the unit off to restart it and it comes back on with the calibration screen but when I touch it nothing happens
  • 508 Answers
Try using a stylus if you have one or a pen (tip retracted) on the screen. Meaning something finer and thinner then your finger. Don't know why but this works on my unit when the recaibration screen comes up.
Posted on Nov 29, 2013
  • 13 Answers
SOURCE: Garmin C330
put your thumbnail under the silver faceplate above where it says garmin and on the right you will see a reset button. It will reset your garmin and you will not lose your information. Hope this helps.
Patti
Posted on Jan 06, 2008
SOURCE: Garmin 2610
Back up the unit then do a master reset.
Switch OFF, Press Page + Menu and turn on, holding the buttons for 5 seconds.
Then recalibrate. I did the recalibrate a few times before it was OK. If you use a stylus when the cross appears and hold it on the screen and move it to the corners you can see the error. Make a mental note and go halfway between the two if it does not calibrate at first go. Then when it calibrates, do it again. I recalibrate every now and again. I think it could be a firmware problem. I will try going from 4.8 to an old version
Posted on May 06, 2008
marcelbakker
  • 174 Answers
SOURCE: Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Posted on Jul 23, 2008
  • 7 Answers
SOURCE: touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Posted on Jan 24, 2009
sharcnet
  • 2130 Answers
SOURCE: Nuvi 255W - directions avoiding highway travel
Yes, you want to select "Avoid Highways" in the Avoidances menu. Please see this link on how to acccess that function.
http://www.sharc.net/discus/messages/6/83.html?1238768270
- Jim
Posted on Oct 01, 2009
Testimonial: "Thank you for the quick answer - much appreciated. That was very helpful"
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
When i turn my nuvi on, the screen goes blank and says "press dot"
Keep pressing the dot, its in calibration mode....
if you need to re-calibrate it this is how...
Turn unit off then back on
Slide Power Key to the right ( lock )
Hold your finger on the screen for 30 seconds until the calibration screen appears
Follow on screen instructions
( this may be where you see more dots)
Oct 30, 2010 | Garmin nuvi 255W GPS Receiver
Screen went blank and when we restarted it the screen comes up as if you're restarting from the beginning when you touch the onscreen icons the screen is locked. How do I unlock it?
its a common occurance on this unit. send it back. it blows fuses, screen maps goes blank with only square dots and no streets. the refurbished units also have these problems.
Sep 20, 2010 | Garmin nuvi 255W GPS Receiver
Nuvi® 255W Car GPS Receiver: My garmin 255w froze. Where is the reset button....
On the bottom of the Garmin 255W is a long sticker...with a Icon that says reset...peel the sticker back and under it you will find a break away tab...the reset button is under there..
May 17, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
Frozen screen
Go here for your answers:
http://forums.gpsreview.net/
Apr 10, 2009 | Garmin nuvi 255W GPS Receiver
Nokia 6126 screen not showing
the problem is in display...better change ur display and use it...
Sep 19, 2008 | Nokia 6126 Cellular Phone
Garmin is frozen on, and will not respond.
Have you tried resetting the unit? Remove the faceplate and press the reset button on the right side of the unit. This may help.
Feb 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Starting up
press the power button for some seconds
Jan 29, 2008 | Computers & Internet
Garmin nuvi 255W GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
