Question about Arcade Raw Thrills Big Buck Hunter Pro Video
Bad gun boards trying to trouble shoot big buck pro gun boards
When light is shown on opto it reacts but no nocitable reaction out of boar sense line board has +5v and grn on board
After open the gun check also the coil or coils in the target if it is open your gun will no work even if the switch's work properly
Posted on Mar 25, 2014
2 Suggested Answers
  • 5 Answers
SOURCE: Big Buck Hunter Pro Arcade game - gun no longer shoots.
Put the game into switch test mode and press the trigger on the n/w gun. If it doesn't register you need to dissassemble the gun as the trigger microswitch has probably failed. You'll need an adapter to remove several security screws. Separate the two halves of the gun carefully as there are springs and other parts that can become displaced and lost. Remove and renew the microswitch adjacent to the trigger. It is a low rolling resistance switch manufactured by Cherry. If you have trouble sourcing one, the same switch is used as a trough switch in modern Stern Pinball machines. You may have to shorten the contact legs on the switch to get it to fit. With care this job can be undertaken by any competent person with intermediate soldering skills.
Posted on Jul 30, 2010
T con board the problem?
Unplug the set for five minutes. Turn the set back on. That completes the RESET cycle and the system should correct itself. If not, it's time to take it into the shop.
Apr 26, 2016 | Sony 47" Class Bravia 1080p 120Hz 3D LED...
How to replace a arcade Big Buck Hunter Pro TV?
If your game has a CRT monitor you will have to stay with a CRT. You can get a great picture from an LCD or LED unit but the guns won't work.
May 07, 2014 | Video Game Consoles & Games
How to fix an arcade screen on a big buck hunter safari machine?
If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
Apr 27, 2014 | Video Game Consoles & Games
Heat element lights up and furnance makes a clicking sound but will not light flame. have replaced gas valve,memory board and heat sensor
This could be a tough one-- for you obviously are experienced with service work-- for you have changed the main valve, and the main memory board!-- now what?
Do you have a trouble shooting guide for the board?
There must be some voltages that can be read, telling you what is locking out the valve from letting gas pass-- (What do the board trouble-shooting instructions say?)
I am sure you know, that the ignitor draws current, and the control board has to sense that current, to let the gas valve open. (If ignitor is broken-- OR NOT THE RIGHT CURRENT!-- the gas valve can not get instructions to open.. Is the ignitor the correct one?)
Then when the gas valve initially opens-- it has to sense flame, thru the Flame sensing rod within a second or two- or it will shut off, too.
Have you purged the gas line, so that good, volatile gas is passing thru the valve those few seconds?
There are no indicator lights, or voltages to give you any clues?
I'm trying to help you think of some way to get the board to help you analyze the clues.
Sorry I can't help more.
Mack B
Jan 16, 2011 | Heating & Cooling
just curious if you still have that broken gun? I am a sculptor in MN and making a piece that i wanted to put a lazor into a broken big buck hunter gun to shoot up at a sensor on a deer which would make it wink at you. thats the plan atleast trying to find a gun. thanks kari
Nov 25, 2009 | Arcade Raw Thrills Big Buck Hunter Pro...
Wher can I purchase a replacement circut board for an Arrow ET200 Eletric Nail Gun. What I have is an ET200 - 110v Rev.2 I would like to purchase on line.
Do you still need this? I have a good board from my ET200. I dropped it, and the piece that keeps the nail driver steady when it shoots in & out broke off. However, the gun still functions fine. Let me know.
Oct 09, 2009 | Arrow ET200 Electric Brad Nail Gun
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Vizio model L37
here, try the trouble shooting guide and let me know start with page 56, here is the link
Let me know when you have tried the trouble shooting for picture and sound even though this may not help, Also, since replacing the board didn't work, I will suggest going right to the manufacturer on this since the board was the only thing that really made sense for both to be out. Otherwise there might be a loose connection somewhere, anyway call them and let me know what they tell you and if they can't help, then you might have to take it in somewhere to have it checked, but the main board is the only thing that really makes sense
Main support number 714-668-0588
Email supporttechsupport@vinc.com
Mar 24, 2008 | Vizio L37 Television
Arcade Raw Thrills Big Buck Hunter Pro Video Logo
226 people viewed this question
Top Arcade Toys Experts
ray gallant
Are you an Arcade Toy Expert? Answer questions, earn points and help others
