I pulled my WEGA kf42we610 apart to replace optical engine, and clean out 4 years of abused dust bunnies. needless to say I disconnected some of the cabling and I'm now having issues putting it all back together. does someone have a simple diagram that shows how everything cables back together. something like "connect B cable on C2 card to Front or side conector on optical block. Many thanks.
  • drjurman May 08, 2009
    Thanks welcomejee this will work perfectly.
    David
  • 10,594 Answers
You need to have service manual of KF-42WE610 to put things back in TV and connect cables in right connectors because service manual has wiring diagram, exploded views info.
Click HERE to download free copy of service manual. Please download all 6 files and unzip with WinRaR software to get PDF file.
Hit "add a comment" button for further query / info.
Thanks.
Posted on May 08, 2009
There are thousands of small blue dots on the screen of my Sony KF-42WE610 that make the pictures look rough. Additionally, the pictures are too green in spite of color adjustment. How can I fix these 2...
both problems would most likely be fixed with and optical engine replacement. due to cost it may not be economical to repair new purchase may be smarter. part number---A-1606-006-A $668.51plus tax and labor.
Dec 22, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
How do I change the optical block in a sony tv
Disconnecting wiring from power supply block
This step may be optional, if power supply block must be transferred to purchased replacement optical block. Undo the blue plastic-coated wire holders to release the two wire bundles. Disconnect the connectors shown with the dotted lines in the photo below. One, which presumably provides power, is disconnected directly from the power supply block, and the other is a regular wire connector.a837b7e.jpg
moz-screenshot-2.pngDisconnecting the optical block fan wires
Disconnect the optical block fan wire connector:
Disconnecting the wiring from the optical block circuit board (C Board)
Carefully pull up on the three wire connectors directly connected to the top of the C Board:
Final wire disconnection from C Board
Remove the screw and gently pull the blue ribbon ribbon cable out of the side of the C Board:
Your optical block should now be entirely free of the TV and ready to ship. I recommend adding specific protection for the projection lens, then sealing the whole unit in a bag to prevent infiltration of dust or packing materials, then carefully packaging it with substantial padding.
Removing the projection lamp (in cases where you are installing a purchased replacement optical block)
Loosen the hex screw next to the projection lamp housing, and pull the lamp and housing outward from the metal clips.
Picture of replacement optical block for KF-60WE610 (courtesy John Setar)
Here is a picture of a replacement optical block for the KF-60WE610. Note that some parts of the old optical block need to be removed and installed on the replacement block.
Jan 25, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KF42WE610 42" turns on and off
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Cool site. hi, i have sonny wega 42 inch 610 issue with blue
Its blue LCD mounted in light engine (optical block) and requires replacement.
Before, the solution was complete light engine replacement but now Sony Service Center will replace blue LCD only to fix it to reduce your repair cost.
Jan 30, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
I have a Sony Grand Vega KF-42WE610, and there is half moon of blue dots in the middle bottom section of my screen on every input. The unit is 4-5 years old and the buld was replaced about 2 years ago. The...
Replace Light Engine -Cost of Rebuilt Light Engine If they have any is not Cheap!! Just replaced one for customer in a 55 sony vega, they paid over $5,000.00 for it Repair Bill was $1950.00 Call UED and ask them if they have any rebuilt ones,and cost 1-800-648-6657 .
Dec 24, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Cleaning Optical Block
Sorry to be teh bearer of bad news, but the optical block (light engine) can not be dis-asembled outside of a cleanroom. You can remove the rear cover of the set and clean the mirrors and glass. That may help, but usually these typesd of symptoms are an indication that the light engine is starting to fail. The light engine can be replaced by you if you feel comfortable. The part is still available.
Keep us posted.
Dan
Aug 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bottom Corners Turning Black
You have a bad optical block assembly.
Dec 25, 2007 | Sony Grand WEGA KF42WE610 42" Rear...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
