Question about Kitchen Ranges
Need installation manual for Shacklock Orion Coal Range
How do I install a Shacklock Orion coal range
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
  • 213 Answers
SOURCE: frigidaire convection free standing range
new ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
Posted on Nov 25, 2007
  • 2427 Answers
SOURCE: ventilation for an island installed range
is this what you are looking for ?
http://www.absolutehome.com/home/3/index81.html
Posted on Jan 10, 2008
muttandjeff
  • 359 Answers
SOURCE: Need electrical information for electrician to install new power
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
Posted on Dec 23, 2008
fknstart
  • 404 Answers
SOURCE: kenmore range broiler burns orange not blue and leake gas
probally wrong gas pressure
Posted on Jan 05, 2009
HOW DO i SET THE CLOCK ON MY F&P Shacklock RA6102MEWS RHM 104943 RANGE
check the manual.....or play around with the buttons until you get it right....
Mar 31, 2018 | Kitchen Ranges
Can someone supply me with a coal plan for a Trident Gas Fire?
Google make and model should pick a manual from there .
Jul 20, 2016 | Heating & Cooling
What bolt size does a 98 Chrysler Town And Country LX 3.8l take for the coal pack. I have1 bolt on it need 3 more.
The 1998 Chrysler Town & Country does not operate on coal. It has a gasoline engine. There is no "coal pack."
Aug 24, 2014 | 1998 Chrysler Town & Country
I added coals to my Charbroil Deluxe 7000 grill, and then they disintegrated. Have I ruined the grill?
Is the grill that you are using gas? If so make sure it is compatible to use with coals. You might also be looking for briquets.
Jul 28, 2012 | Grilling
Changing bulb in dimplex cht20 fire
Yes this is very easy on the cheriton range of fires.... remove the coal, then remove two screws from the front of the coal holder... the whole brass coal holder will pull away from the machine. The bulbs (two of them) are located directly behind this, just behind the rotisserie flame effect. The flame effect can be pulled out of its holder to access the bulbs.
Feb 19, 2012 | Heating & Cooling
I need a manual for Monarch 24PY-2SW Kitchen Heater
Sorry this item is not in my area of expertise.
Nov 28, 2011 | Office Equipment & Supplies
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
