How to clean a scratched cd - Audio Players & Recorders
    Habit-Forming:
  • 72 Answers
You cannot fix your disc it's already remarked with the scratched data even if it's a slight scratches as the disc is stale so it's not possible to fix your disc
Posted on May 14, 2016
    Guru:
  • 166 Answers
I got this, solved my issue with cd's how to fix scratched cd cheap
Posted on Mar 05, 2016
    Problem Solver:
  • 15 Answers
For many years I have been using turtle wax... the paste. make sure its not the abbrasive type... the was fills in scratches and makes the DVD's and CD's play. Just rub on the CD, going across the scratch so it fills in. Then wave the CD back and forth in the air to make the wax dry... then rub off with a lint free towel. Been doing it for years and no ill effects to CD's or DVD's... fills in most scratches (if scratch remains reapply.. 2 coats makes most scratches small enough to play through).
Posted on Nov 28, 2013
CD player skipping. Cleaned the lens but problem still exist
Try cleaning the disks as fingerprints and scratches can lead to read errors which are heard as skips.
Some cleaning solutions or reconditioners contain a special polymer that will fill in light scratches.
Apr 13, 2015 | Audio Players & Recorders
Tip
How to Fix a Scratched CD
Clean the disc. Even if a CD isn’t actually scratched or scuffed, dust, oil, and other surface contaminants can prevent it from playing properly. Thus cleaning the disc should always be your first move. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+1162261192+0674921071+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google
Fix It Scratch RemoverRepairs Scratches Like Magic! As Seen on TV. Guaranteed.
www.AsSeenOnTvAdvisor.com/FixIt
  • Run warm water over the damaged disc to remove dust.
  • If there is stubborn dirt or grease on the disc, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Any time you rub or wipe a CD, you should do so by starting at or near the center of the disc and rubbing straight outward toward the edge to prevent further scratching.
  • Shake the water off and let the disc air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
  • 2Try to play the disc. Many times a good cleaning is all that is needed. If, however, problems persist after cleaning, try to play the disc in a different CD player. Some players handle scratches better than others; computer CD drives and car stereos tend to be the best.
  • 3Burn a new disc. If you can get the CD to work in one CD player - especially your computer’s - but not in others, try burning a new disc. The CD burner on your computer may be able to read the CD well enough to produce a perfect copy. You may wish to try this even if the CD doesn’t play correctly on the computer.
  • 4Locate the scratch. Actually repairing the disc will be easier if you can figure out where the offending scratch is. Visually inspect the CD’s playing surface for scratches or scuffs. Scratches that run perpendicular to the CD’s spiral - that is, those that run generally from the center to the rim - may
  • on Mar 23, 2010 | Computers & Internet
    WHY DO MY CD'S SKIP WHILE PLAYING.?
    The CD is cracked or its having scratches.
    Aug 28, 2014 | Audio Players & Recorders
    Crc on almost every DVD
    A CRC error is a data check - cyclic redundancy check,
    Either the DVD discs are dirty or scratched OR the DVD drive needs the laser lens cleaned OR the DVD drive is faulty.
    If the DVD discs are scratched you may be able to polish out the scratches with a CD scratch removal kit.
    Try cleaning the DVD drive with a CD drive cleaning kit to clean the laser lens.
    If none of this works the the DVD drive is faulty and needs to be replaced.
    May 17, 2011 | Computers & Internet
    My cd player stops while playing and shows er on the display
    Try checking for dust on the laser eye, A fine, clean and very soft artists brush will do for cleaning or perhasp the CD has a miniscule scratch on the surface. You'll know if it is a scratch as the CD will always stop in the same place. CD's and DVD's should only be wiped clean with a very clean duster in the direction of from the centre hole to the outer rtim of the disc. Never ever wipe anything across the whole surface from one side to the other or wipe in a circular motion. There a quite a few products on the market that will help you keep you discs clean. Just google CD (or DVD) cleaner. CD's and DVD's are quite forgiving in how badly scratched they can be and still play. It only takes a small scratch or dent that can only be seen under magnification to deflect the laser beam off track.
    Mar 15, 2011 | Memorex MD6451R Personal CD Player
    My CD 2 for Microsoft flight simulator x is scratched. What i can do?
    Theres not much you can do your self but if you take it to a dvd or game store they should be able to clean it.
    Nov 08, 2010 | Microsoft Flight Simulator X for Windows
    Console not being read
    Try updating the firmware... Also, check if any other disc works or not.. If it does, then get the disc which you have inserted is at fault, try to replace it... If that's not possible, try cleaning it by various methods... If all else fails, and you have no other option but to throw that disc, try using toothpaste on it ... It works sometimes..
    Nov 23, 2009 | Nintendo Wii Console
    Scratched cds
    anything can be repaired . with enough money and time anyways..
    I don't understand why the discs would be getting scratched though.... the only thing that touches the readable surface is a laser.
    Maybe the unit is just dirty. Call a local repair shop and ask how much to clean it up... I had a CD jukebox with a 600 disc changer cleaned for under $100 not long ago.
    Jul 12, 2008 | Technics SL-MC4 61-Disc CD Changer
    PS2 GTA: San Andreas Disk Problems
    this shows that your cd is already damaged, the scratches might have hit the critical part. you said that some other cd's of yours have also scratches these are presumably minor scratches. its better if you purchase anew one. a damaged cd with deep scratches can damage the lense of your cd rom if you continously use this it would soon permanently damaged the lens
    Dec 02, 2007 | Video Game Consoles & Games
    206 people viewed this question
     Grubhead
    Grubhead
