Question about Apple iPhone/iPod External Battery Charger - (1900mAh)
How can you tell when your soundlogic Xt charger is fully charged?
I have a soundlogix XT external battery that charges off of a computer. How can I tell when it is fully charged?
SOURCE: battery not charging
Since it is only a month old you need to take it back. These devices have a smart battery. Most of the time in your situation, the charger itself is the issue. Have you tried charging it by computer usb?
Also, one thing you can try is a hard reset if you hav't already. A hard reset is holding both the lock and home key until you see the apple appear. You could also do a firmware upgrade but I would highly suggest that you take it to an apple store before modifying anything since its so new.
Hope this helps.
Posted on Aug 21, 2009
SOURCE: My iphone's home button hasn't worked for a week
I do not recommend taking the iPhone apart yourself I've personally seen where my clients have done exactly that and broken the charge port or cracked the glass or ripped one of the ribbon connectors. If the home button is not responding you should have a technician look at it.
With that said...
If you absolutely cannot hire a technician...
There are two screws on the bottom of the phone once these are removed the screen assembly can be lifted slowly up from the bottom first - Please do not use a screwdriver to pry it up a suction cup will do the trick (the kind that holds a GPS to the windshield of your car should work). Once you have lifted the screen assembly look underneath toward the top right there are 3 ribbon connectors you can use your fingernail to pry up the connectors freeing the ribbon !-be gentle as these are fragile-! Your home bottom and it connector are located at the bottom of that screen assembly. You will see 2 gold connectors extending from the bottom of the screen. Be gentle with those they break EASY check where they make contact with the board are the contacts clean?
Is the button depressing(does it feel like a click?)?
--It may be that the small round metal piece that helps the button to depress has moved out of place and the button is no longer making contact.
Beyond this you will need a new button assembly which is quite tricky to replace since it is fused inside with the glass.
???!-Maybe time for a pro!???
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank you and Good Luck!
Posted on Feb 09, 2010
  • 192 Answers
SOURCE: iphone wont charge
http://support.apple.com/kb/HT1808
Posted on Apr 13, 2010
MarkusG
  • 167 Answers
SOURCE: my iphone says its fully
And the problem is...?
Posted on Mar 07, 2011
  • 643 Answers
SOURCE: My iPhone won't charge. When i connect it to
your battery seems to have a damaged cell, replace the battery and it should run fine
Posted on Mar 14, 2011
Soundlogic XT 7800 battery pack will not hold charge, the 4 blue led's go out when you disconnect power lead
If your laptop battery won't hold the charge, no way, you must buy a new batery pack
Aug 29, 2015 | Computers & Internet
SoundLogic XT #BOW-6/5998 No power anymore. Won't recharge anymore.
Make sure the charger is working properly. if ok, replace the battery.
Apr 13, 2015 | Audio Players & Recorders
My portable charger wont stay on. How do you make it stay on to charge the phone?
If you're using the charger supplied with the phone, it should either work or not. If it doesn't; either the phone battery, charger or both require replacement.
If the battery is "good" and you are using a "3rd party" (non-original equipment) charger, you may not have one that is incapable of providing the correct voltage, charge current or both. If the charger can not provide adequate charge current or voltage, it is very possible that the charger is shutting off due to excessive heat. Once sufficiently cooled, it charges again.
Make sure that you've got the correct charger - or one that is designed to charge the type battery in your phone at the correct voltage and current rates.
Apr 08, 2015 | Cameras
Where can I find a printable User Manual for a Soundlogic XT 2600mah power bank
There doesn't seem to be any owners manuals available online?
quite a few youtube videos...
SoundLogic XT PowerCell ' Unboxing & Demo: http://youtu.be/YfkVB26EmIM
or you could try contacting the company... SOUNDLOGIC Contact Us
Mar 06, 2015 | Electronics - Others
Connecting wifi soundlogic xt android touch screen netbook / tablet
I purchased a soundlogic xt netbook and I can't connect to the wifi. I did everything the instructions said, but still no luck.
Nov 06, 2012 | Coby Tablets & eReaders
Whats the best way to charge the bluetooth parrot b250-xt
It doesn't make a difference if you use the car or house charger. When the green light comes on, it's fully charged. If you are having a charging issue, you can try installing a fresh battery. I have been in contact with the overseas supplier of these batteries and am offering them for $20 via PayPal once my shipment comes in. Please contact me at ebhammonds@gmail.com.
Oct 26, 2011 | VXI Corporation Blueparrott B250-XT...
Camera shows battery dead. battery is fully charged. opened battery dor and battery ok. added lens and battery shown as needing charge.
You probably have a faulty battery or charger. If you know someone with the same camera try swapping batteries. If not a new battery sounds like your next move.
Good Luck
Jun 16, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Apple iPhone/iPod External Battery Charger - (1900mAh) Logo
392 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
