Question about Refrigerators
Samsung not defrost
    Top Expert:
  • Refrigerators Master
  • 12,957 Answers
Defrost timer, and/or defrost heating element not working. If modern unit could also be the modular control board.
Posted on Nov 28, 2013
How to turn my refrigerator off to defrost
Your model has a control Board that most likely automatically controls periodic defrosting. If it's not defrosting, then that Board, the heater, or defrost thermostat is bad.
Sep 07, 2017 | Samsung Refrigerators
Samsung RS2544SL/XAA getting iced and freezing
In freezers if it's getting ice inside body surface? Sometimes refrigerators doesn't defrost ice completely and shut the drain water line of defrosted ice. If you doesn't have checking instruments for defrosting heater element and other parts, there id's wary wary to defrost ice once completely once. Thank you
Oct 17, 2016 | Samsung Refrigerators
Freezer door code is reading -25 on a samsung refigrater
Error 25 is fridge defrost fault, could be defrost sensor or defrost heater.
Ian.
Aug 19, 2015 | Samsung Refrigerators
How do I put Samsung modal rb215 lash refrigerator in defrost manual? Evaporator keeps freezing up!
defrost system MUST function automatically in order fro refrigeration to function. It sounds like you have a malfunction in the defrost system. Find the time and advance into defrost cycle. If defrost cycle begins (The fridge will stop running and water will start trickling after a few minutes), replace the timer. if not, you may have defective heater or defrost thermostat.
Jul 01, 2015 | Samsung Refrigerators
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
My 3 year old bottom frezer samsung fridge stoped defrosting automatically.Ice builds up in vents till stops cooling.After unpluging and defrosting for 24 hrs manually,works good for 2-3mnths.Cant find...
3 things defrost heater, defrost timer or defrost limit thermostat.
You can pull the cover inside the freezer exposing the evaporator coils,
look for the defrost heater at the bottom of the coils. Test for continuity.
Find the defrost limit thermostat, a 2" metal disc attached to the evap coil usually on the side towards the top has two wires going in and will have continuity only when it is cold. If those are good probably the defrost timer.
Nov 04, 2009 | Samsung Refrigerators
SAMSUNG RS267LAPB
You have a defrost component failure. Either the defrost thermostat or defrost heater most likely. Bypass the defrost therm and place into defrost by turning defrost timer clockwise until you hear a loud click. if heater comes on then defrost therm is bad .If heater does not come on then it is a bad heater. you can check continuity with a ohm meter Hope this helps
Jul 27, 2009 | Samsung RS265LABP Side by Side...
SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Mar 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Every 3 - 4 weeks i have to defrost my samsung side by side fridge freezer with a hair dryer as the cooling system keeps icing up
you have a defrost problem there are Three parts to it a Defrost control board a Defrost Heater and a Defrost bi-metal thermo-disc I would check the heater first it is in the coils you are defrosting
Jun 09, 2008 | Samsung Refrigerators
I have a Samsung RS2556BB Refrigerator, purchased in end of year 2004. Looks like the defrost stopped working, cause freezer stop working. A Technicain came as directed by Samsung Customer care, he said it...
Justy a piece of junk. The display has nothing to do with the defrost. Hold your top two buttons for 10 seconds and the displays will reset..good luck.*****
May 30, 2008 | Samsung Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
