Question about Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361
Thermostat stuck on hold won't reset.
Thermostat stuck won't reset or change.
    Master:
  • 571 Answers
Pull the thermostat off the wall & place back into pins. Should reset.
Posted on Dec 11, 2013
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
What does the hold button on my pro select analog thermostat used for
"HOLD" is to override any schedule in the controller and HOLD the current setting.
Nov 13, 2014 | Heating & Cooling
My robertshaw 9620 thermostat is stuck on 70 and i can not change setting frim temp or time.
Here's how I fixed my Robertshaw thermostat that was stuck at a 70 degree reading for almost 2 monthes. When I turned on the air conditioner or heater it wouldn't stay on. I removed the cover panel and dusted off the inside which the guy at local hardware store suggested. That didn't work. Then I noticed the words "reset" right on the green circuit board on the left side. There's a very small silver button. I pressed on it and everything reset. Less than a minute later the thermostat is reading the correct room temperature. Now my air conditioner and heater are working properly.
Mar 16, 2014 | Robertshaw 9620 digital...
LG LHT754 stuck on dvd function and won't change input
Hold down "2" on the remote simultaneous to "stop" on the receiver. In a couple of seconds you will see something appear on the display. OPO-63? Anyway, repeat the process again when you see that. The system will reset. This will also take care of the inability to switch to AUX or Ipod.
Feb 16, 2013 | LG LH-T754 Theater System
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Oct 30, 2012 | Cell Phones
Fan wont come on
You may have a faulty thermostat. If its stuck closed the fan won't run. Thermostat tells the car when to turn on/turn off the fan based on how hot the engine is getting.
Jul 29, 2012 | 1998 Honda CR-V
My thermostat is stuck on hold program at 82 degrees even whn I change is it goes back to 82.
Hello my name is Heath it will be my pleasure to assist you. The first thing you need to do is hit the run program button and this will get it off the hold function.
Sep 05, 2011 | Honeywell Programmable Thermostat Heater
MY White rofers 1f78 is stuck
Reset operation the system must be at cool position then press UP, DOWN and TIME buttons simultaneously. If the reset did not work call the hometechline 18002842925.
Link: MANUAL
Jul 20, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361 Logo
456 people viewed this question
Top Thermostats Heating & Cooling Experts
john h
Lawrence Oravetz
Are you a Thermostats Heating and Cooling Expert? Answer questions, earn points and help others
