Question about LG LRE30453ST ceramic convection range
HS light stays on lg electric range
HS light will not reset when burner is totally cooled off
Lg STOVE MODEL LST5651SW BURNER STAYS ON, DIDNT NT TURN OFF OR COOL DOWN ONCE TURNED ON
Its not the burner, but the switch or relay it controls. With a meter you can track it down an order the part yourself. Be sure to look for things like bugs. I found a bug in a clock that caused problems once. Becareful you are dealing with high voltage. If you are not sure call a tech.
Jan 28, 2015 | LG range & stove radiant cooktops...
How do i shut off hot service light and cool the burner
Good Afternoon Friend,
I understand you want to know how to turn the "Hot" service light, and cool the burner on your Frigidaire cooktop, model# GLEC30S8. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any burner. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire 31 in. GLEC30S8 Electric...
Why burner on light on stove wont come off
After stove is turned off, the light stays on if burner still warm. If the burner never came on, then it needs to be replaced with new one.
Apr 26, 2014 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Hot Surface Indicator Light has not turned off since last night.
if the hs ind light does not turn off then that particular heating elemnt needs to be replaced.heat sensor is built in the elemnt.when elemnt is turned off and it cools down it makes a switch to open and inturn ind light turns off.but sometimes thst gets stuck and light remains on.but do not worry abt element,it remains off,its just that indicator light that remains on.
Jul 30, 2009 | Jenn-Air JED8430 Electric Cooktop
LG LRE30453ST ceramic convection range Logo
51 people viewed this question
Top LG Cooktops Experts
cwradio73
Dan Apthorp
ray gallant
Are you a LG Cooktop Expert? Answer questions, earn points and help others
