Question about Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361
Thermostat stuck on hold. - Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361
    Master:
  • 571 Answers
Pull Tstat off wall & place back into pins. Or just disconnect the red wire & re-connect.
Posted on Dec 11, 2013
1999dodge ram has cool heat at idle gets hotter when you drive or rev engine
Sounds like a bad thermostat, REPLACE IT! And make sure coolant is at proper level. A thermostat should be closed when cold, and wide open at hot engine. if it fails, it will not stay closed at cold engine, or its stuck. When stuck water flows through by pass at thermostat. and does not heatup because thermostat does not hold coolant back until it gets hot. God-Bless!
Dec 15, 2016 | Cars & Trucks
Where is thermostat? How test it
Hi L Rod:
- Thermostats are usually located on the top of the engine, under the fitting that is attached to the hose that connects the top of the radiator to the engine.
- If the engine is running too cold it could be stuck open.
- If the engine is running too hot, it could be stuck shut. There could also be a lot of other possible causes.
- To test a thermostat, remove it from the engine. Do this when the engine is cold. The thermostat should be closed. Use pliers to hold the thermostat and immerse it in boiling water. It should open.
Sep 23, 2015 | Cars & Trucks
My 84 ranger motor won't heat up runs super could on interstate it will get a little warm then right back to cold any ideas?
I would say your thermostat is stuck open, not allowing the engine to heat up. You can cover your radiator about half way with cardboard and see if it heats up. If it does, the thermostat is stuck wide open. Replace the thermostat. I hope this helps Good Luck
Feb 19, 2015 | 1984 Ford Ranger
Stuck on hold wont run program
Hi Ladies and Gentleman,
Here is a direct contact. Call their live customer service hotline 1-800-284-2925. They are open from 7a-5p central standard time.
Here is a link to how to set up the Thermostat video if you are up to do-it -yourself.
Programming an EMERSON 1F80 Thermostat
Manuals on line provides instructions for hold on your model to choose Free Emerson Thermostat User Manuals ManualsOnline com.
OK. Here is an example pdf. I used for you. http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6175.pdf . Download. Go to page five (5) of Operations. Gives a detailed explanation of HOLD function.
Now. In short. Here is your answer should you like to try it. Go to unit. Press Hold for (5) five seconds. Time will blink. Set the time to " 0:00 " which disable's the function by using the up down buttons.
Note. Displays currently programmed set temperature (this is blank when the System switch is in the OFF position). Go for it.
That should do it That should do it. The reference's are submitted for future use and learning. Fare. Well .
Fff
Fare. Well.F
Apr 10, 2014 | Emerson Heating & Cooling
Thermostat stuck on hold won't reset.
Pull the thermostat off the wall & place back into pins. Should reset.
Nov 27, 2013 | Thermostats White Rodgers 1F80-261...
My thermostat is stuck on hold program at 82 degrees even whn I change is it goes back to 82.
Hello my name is Heath it will be my pleasure to assist you. The first thing you need to do is hit the run program button and this will get it off the hold function.
Sep 05, 2011 | Honeywell Programmable Thermostat Heater
Thermostat control
I would like some help programing the thermostat in my house. Hunter, Model 44300A
Thanks,
May 05, 2008 | Hunter 30124 Air Conditioner
Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361 Logo
117 people viewed this question
Top Thermostats Heating & Cooling Experts
john h
Joe Lane
Are you a Thermostats Heating and Cooling Expert? Answer questions, earn points and help others
