Question about Refrigerators
Ice maker freezing up
The ice maker makes very little Ice
    Scholar:
    New Friend:
  • 81 Answers
The water line to your unit may need to be replaced. Check how fast water comes out of the dispenser. If it's trickling out or takes 30 seconds to fill the glass, you have poor water pressure to the unit and it's causing the fill tube to freeze.
Posted on Nov 28, 2013
HVACRH20
  • 237 Answers
SOURCE: My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Posted on Jan 31, 2007
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
SOURCE: Very little ice
the problem may be connected to the mineral content in your water supply. Particles can bond at the valve/water supply line entry point and restrict flow. Turn water supply off, remove icemake line, carefully screw openings, have someone open water valve and expel particles. a solid stream means it's ok. A dribble means it needs more reaming ..repeat if necassary. If flow is good and ice crescents are still small then the icemaker valve on the refrigerator may need to be replaced. A quick fix can be tried by taking off the IceMaker face. Increase duration of fill by turning adj. toward "+''. judge lar
Posted on Jun 27, 2008
jonniewalker
  • 1031 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
SOURCE: ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Posted on Apr 09, 2009
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
Icemaker not making ice cubes.
Amana SXD22S2W refrigerators are made by Whirlpool and what you have happening is common with a couple possibilities. Most likely the W10245167 Water Inlet Valve is not shutting off after the fill time of about 7.5 seconds. If this is happening the water will slowly fill the ice maker tray above the lever that it should and causes the ice to connect together on the top thus not allowing the cubes to be harvested because they are basically welded together as a whole piece. And the other possibility is the ice maker itself is needing an adjustment of the water flow time. Below I will post a Icemaker Repair video telling how to adjust the time and other things to look for. This is possible but most times not always the case. Adjusting the flow time is delicate and a little change can cause too much or not enough water. Lets watch the icemaker a little closer and see if there is ice freezing up in the fill tube behind the ice maker. You have seen the leaky faucets before and an old W10245167 Water Inlet Valve can do just that making a mess inside your freezer and ice maker if leaking. Here is a Whirlpool Ice Maker Troubleshooting PDF You can find this info on this page HERE You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I will be here should you have any questions, Thanks Sea Breeze
D7824706Q Ice Maker Assembly
Aug 13, 2012 | Refrigerators
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
GE ICE MAKER, VERY LITTLE ICE,
I had this problem with my GE ice maker not working and it was an unbelievably easy fix. If you have the same ice maker then you will see a green light by the power switch. Below the ice maker is a "paddle" ice sensor. The paddle is attached to the ice maker and there is a coil type tension spring. If your paddle is loose, make sure the end of the spring (the pointy wire end) is inserted into a small hole. You probably can't see the hole but move the wire end until it pops into the small hole. You should now have tension on the paddle. At this point I had heard that the freezer light bulb may be drawing too much current for the ice makers motherboard. I removed the bulb and, UNBELIEVABLY, the ice maker began making ice! Try removing or replacing the LIGHT BULB first!
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Too much water is being dispensed when filling to make ice cubes. Water pours into ice bin and freezes. What to do?
You have to close the water supply tap from the source a little. This will decrease the volume of water being pumped into the ice maker. If this doen't work then you need to replace the solenoid valve that feed the water to the ice maker.
Jul 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker making little ice/Leaking water on floor.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
Feb 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker grinding sound
I found I get a odd clicking noise whenever the icecubes freeze inside of the box in the top left. You'll see about 20 little fingers, arms, or whatever you want to call them that spit out the ice into the container...make sure those fingers/arms arent stuck from the ice.
Jun 11, 2008 | Maytag MSD2651 HE Side by Side...
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
