Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Errore code c-d307
I went to print on my Konica Minolta C-250 and it didn't power up like normal. So I reset it using the rocker switch by the toners. When it came back up and all the language is in Japanese, it has an error code C-D307 displayed on it in english but that is it. What can I do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Sounds like a bad NVRAM board. When it goes bad it resets everything.
Posted on Nov 14, 2014
Kevin Hayes
  • 167 Answers
SOURCE: Konica Minolta bizhub 250 malfunction error 3452
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Posted on Jun 12, 2008
freetek
  • 5568 Answers
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Posted on Oct 10, 2009
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How to fix error code c-3725
c-3725 -> Fusing abnormal high temperature detection. To get rid of this code, you have to follow the below procedure:
1. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed;
2. keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.
3. Restart it normally and it should work.
If the error is still there, you might need to replace the fusing unit. If you need anything else, just drop us an email at office@bizhubreset.com also, visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 14, 2014 | Konica Minolta Bizhub C550
Minolta Di152 how do i reset error code cof 32 for developer
Has the developer been replaced along with the drum They are normally replaced as one. If not that is why it is coding out. If not with power off then on have tech come out and replace the developer and drum mite require the sensor in the developer cartridge mite be bad.
Apr 29, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
When i power on the machine it give the error C-D307
Abnormality is detected by the abnormal check of each NVRAM Data. Need to have tech come out try to re flash the firmware on the machine worse case you need a new control board and the Non Volametile memory is gone which house certain counter info and boot info for the copier not available on the internet only secure site at Konica Minolta they want to protect their software
Feb 15, 2014 | Konica Minolta 2 Pack Bizhub C-250 C-250p...
Reset code No error display but all print out is
Check the toner/drum cartridge. reboot the printer. This could've a high voltage power supply issue.
Oct 17, 2013 | Konica Minolta Magicolor 3730dn 4750...
Konica minolta pagepro 1500w toner low error
recharge toner powder. 'BROTHER' toner powder is suitable for it.rate 100 Rs. only.
Sep 15, 2013 | Konica Minolta PagePro Office Equipment &...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
188 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
