Question about Canon PowerShot A75 Digital Camera
Camera will not operate
In the Off position the lens stays extended.  If I am successful in turning the camera on, the lens retracts, the screen stays black, the camera makes a beep-beep-beep sound and then the  screen shows "E18" in the corner before the camera shuts off (on its own) and the lens extends again.
    Problem Solver:
  • 3 Answers
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Posted on Oct 15, 2007
SOURCE:
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
The lens on my Canon Powershot S2 IS Camera is stuck in the extended position. Code on screen E18
This is a very common in digital camera's caused by debris getting into the lens housing, get a can of compressed air attach the straw and give it one or two blasts between the crevice "camera body and lens housing" try the power! if that fails, try tapping on the lens housing with the side of your finger "gently" if successful aim the lens down towards the floor and extend and retract the lens a few times to further clean out any additional grit.
Jan 19, 2011 | Canon PowerShot S2 IS Digital Camera
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot A75 Digital Camera Logo
126 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
