Question about GE Profile Spacemaker Over-the-Range Microwave
Wiring diagram jvm1650 - GE Profile Spacemaker Over-the-Range Microwave
Can the door to the GE Spacemaker JVM1650SH05 be removed easily & replaced?
We have the service manual and have uploaded it to our site here for your convenience. See page 19.
You can also find helpful exploded view diagrams and order needed parts by entering your full model number here.
Apr 29, 2011 | GE JVM1650 1000 Watts Microwave Oven
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650 microwave oven totally inoperative.
There will be a fuse, a cavity TCO (thermal cutout/thermostat) and a magnetron TCO.
These are the parts to check.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here. (Don't forget the suffix).
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Feb 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650 microwave over totally inoperative. No lights
That's usually a blown fuse, cavity TCO or magnetron TCO.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing and possible replacement (such as the cavity TCO) will require you to remove the oven from the wall.
GE JVM1650 Resets After Two Seconds of Operating
Im still trying to figure it out. I have the same issue. The weird thing is that if i unscrew the touch pad control panel and let it hang (wires and all) it works perfectly!
Jun 01, 2008 | GE JVM1650 1000 Watts Microwave Oven
Same problem- microwave shuts off
You have a bad magnetron. The fact that it works when the board is tilted is the giveaway.
If you don't want to pay for the service call and prefer to do it yourself, please note the safety and parts links below:
We have *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Removing and replacing door assembly
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Dec 08, 2007 | GE JVM1650 1000 Watts Microwave Oven
JVM1650 not heating
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
Dec 02, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
56 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
