Question about Refrigerators
Electrolux ese5688sa cooling fan is not working
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
If you can confirm power to the motor and it is still not running, then a new motor is needed.
Posted on Nov 28, 2013
Testimonial: "the both cooling fan are missing I need the part number and power rating of oth"
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
Parts catologe of electrolux ese5688sa refrigrator
Go to appliancepartspros.com with the model number of unit.
Nov 27, 2013 | Refrigerators
Very noisy cooling fan.
The only way to fix it properly is to replace the cooling fan I have tried every other way possible at some point
Apr 21, 2012 | Electrolux EOG6330 Gas Single Oven
Electrolux Gas Oven EOG6330; Cooling fan still on several hours after oven turned off. Solution, please.
hi the change over stat is probably faulty one of the wires from the cooling fan will go directly to it. there are 3 wires on it. just replace it. 311 23 97-00/9 is the part no approx £18 +vat
Feb 09, 2011 | Electrolux EOG6330 Gas Single Oven
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Main oven switches itself off
sounds like cooling fan not working. check the fan and a limpet stat that switches it on. without the cooling fan the oven cabinet overheats and a safety cuts out the oven.safety stat could be faulty if no prob with other stuff.
Jul 20, 2010 | Electrolux EOU6330 Electric Double Oven
Electrolux EOB6630x - Oven switches off after 10-15 minutes, then back on again after it has cooled down, obviously the overheat stat is working otherwise it wouldnt switch itself off, what part is it that...
there is a casing fan which is operated by a fan stat.remove top cover and it shoud be accessible. check it is free to rotate and has continuity. fan stat is located on top of oven as i recall
Nov 16, 2008 | Electrolux Kitchen Ranges
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
