Question about Frigidaire Kitchen Ranges
FEFL79DSF Electric stove, is not heating up properly
When i need the temperature to be at 400 degrees, I need to set the oven to 425 degrees. When I need my oven temp to reach 450, i have to set the temp to 525.
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
SOURCE: Oven does not heat to proper temperature
get a new oven
Posted on Nov 23, 2007
SOURCE: Possible Control board problem
You may not necessarily need a new control panel. Sometimes the oven temperature can be calibrated. Look in your owner's manual (if you have one) for calibration instructions. This will usually take care of the problem. If not, you may have to replace the oven sensor located inside the oven in the upper right or left hand corner of the back wall. Good luck.
Posted on Feb 08, 2008
docjohn174
  • 943 Answers
SOURCE: oven not heating properly
HI thanks for your question. the problem you have is with the bake igniter. a common problem with gas ovens the igniter should be replaced. thanks the appliance doc.
Posted on Oct 12, 2008
vegakitten20
  • 685 Answers
SOURCE: Range will not hold a consistent temperature
here is a site that might be helpfull http://forums.partselect.com/range-repair/index109.html
Posted on Nov 11, 2008
The stove doesn't heat up to the preset temperature. When I set it up to bake at 400 degrees, it goes up to 327 and stops heating further. The same occurs when I put it on broil.
If you preset to 450F what does the oven stop at?
Do you have an oven thermometer that you can use to compare against the reading (327F) that the oven gives you?
It appears to me that the oven thinks its hot enough to stop heating. Could be a temperature reading problem, a comparison error, a display error or a calibration error.
Is there another reboot process other than unplugging?
How old is the appliance?
Dec 26, 2014 | Kitchen Ranges
General electric stove not heating up
check the oven temp sensor located in the oven cavity in the upper left corner,at room temperature it should read 1100 ohms
Sep 28, 2012 | Stoves Ovens
My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from...
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Kenmore model 790.9621 electric stove error code F10. The oven heats up on bake (set at 400 degrees) then goes into f10 mode; and seems to be heating up more. Answer for problem??
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Jan 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
19 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
