Question about Samsung LN-S4041D 40 in. LCD HDTV
Rainbow screen vertical rainbow over entire screen but audio ok
  • Samsung Master
  • 684 Answers
Hi Metthew,
Most probably the TCON board in your tv is defective. Please consult some qualified service technician. Most of the time the company service centers ask you to replace the entire LCD panel, which is an expensive affair. TCON board is a small part of the panel. and its job is to distribute the picture information across the LCD screen. Good luck.
Posted on Dec 29, 2013
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
May 10, 2014 | Proscan Televison & Video
Vertical rainbow stripes on my GB color
I would say that the screen is causing the lines in a gameboy colour the lines are not the same like it would be in an orginal gameboy the one with the four batteries. Lines in gameboy color are the screen issues then the whole screen would have to be replaced on the GBC then.
May 18, 2013 | Nintendo Game Boy Color Console
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
LCD HDTV WITH VERTICAL RAINBOW LINES
Polaroids are known for bad capacitors in their units
pull the back off look at the circuit board check for bulging or leaking capacitors.
Jan 24, 2009 | Polaroid FLM-2634B 26 in. LCD Television
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Vertical rainbow on right hand side of screen
Sounds like u have a crack in your LCD panel. Not much u can do except order a replacement panel. If u press on the panel it will rainbow more. Only thing u can is replace it.
Aug 23, 2007 | Philips 15MF605T 15 in. LCD Television
Tube turns on nothing else does
If the Tv turns on (power supply is ok), screen lights up (inverters are ok) but don't get a blue screen, menu options, source options, or audio, it's most likely the main board (aka Motherboard) is faulty. If a DVD player is hooked upto the TV, check whether you can get audio from that (change the source using remote), in such a case it could be a problem with LCD Interface board. My $3 is on faulty Main board.
Jul 27, 2007 | Sanyo Vizon LCD-15A2 Television
Samsung LN-S4041D 40 in. LCD HDTV Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
