Question about PANDIGITAL PANSCN Office Equipment & Supplies
Pandigitak scanner when plugged in reads error
E46 320i 2002 model cranks but will not start.pump pressure is ok at 3.2b plugs have spark what could be the problem
I would first check for error codes using an OBD-II scanner tool- then research the Diagnostic Troubleshoot Code(s) to point you in the direction of the problem. Most common error is when DIYers read the scanner tool and automatically assume scanner codes pulled will pinpoint the exact problem. Scanner tools vary in scope. The bottom line, use the tool as a starting reference point, but you will have to test the component to make sure it is the one that is malfunctioning. You can read more about OBD-II codes at the following URLs:
OBD II Trouble Codes Home
OBD Frequently Asked Questions Scan Tool Center
Feb 13, 2017 | Cars & Trucks
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
2005 hyundia accent obd scanner reads link error
Link error occurs when the scanner can't connect to the computer, make sure the cable is securely plugged in then switch the car on
Nov 17, 2015 | Cars & Trucks
Engine management light
You need an OBD2 scanner to read the error code. It plugs in to your car and is typically under the steering wheel. Autozone will read the error code for free.
May 04, 2012 | Cars & Trucks
Error no is 51.22
go to this link, and read page 12 .. your error is listed as
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
51.20 Error
51.21 Error
51.22 Error
51.23 Error
The device has experienced an internal
hardware error.
51.20 Error-black scanner error
51.21 Error-cyan scanner error
51.22 Error-magenta scanner error
51.23 Error-yellow scanner error
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine
please post positive feedback for me
Oct 17, 2010 | HP Color LaserJet 2600n Printer
Error while communicating with scanner message
Smile...well this is due to a default setting in windows which u need to change.
1. leave the device plugged to the USB & power it
2. Go to device manager \ expand (+) universal serial bus controllers
3. Right-click \ properties \ usb root hub \Power management tab \ uncheck box (allow the computer to switch off the device)
Restart! Don't forget to vote me dear!
Feb 07, 2010 | HP ScanJet 3500C Flatbed Scanner
Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Oct 14, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Scanner failure
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with
the scanner hardware. Perform the following steps to resolve the error:
1. Verify that the scanner bulb is lit. If the scanner bulb will not
light up, the all-in-one will require to be serviced.
2. Perform a Power Cycle on the all-in-one as listed below:
a. Verify that the unit is switched on.
b. Remove the power cable from the back of the machine.
c. Wait for 20 seconds.
d. Reinsert the power cable in the backside of the unit.
3. If the error continues to persist, remove the power cord from any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product.
4. Cold ambient room temperatures may also cause this error. Move the all-in-one to a warmer room and see if the error reoccurs.
May 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
Feb 27, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
