Question about Health & Beauty
Balance tronic model Z17489
PROBLEME OUT 2
How long does it take a tronic 150w power inverter to be fully charged.and how long does it last after being disconnected from charging?
This device is meant to convert DC power from a car battery and similar devices into AC mains power suitable for running small appliances. It is not intended to be an energy storage device. Once plugged in, it does take a few seconds to reach peak output and will remain active a few seconds after input power is removed. This is due to the slow collapse of the magnetic field generated by the internal transformer that feeds the AC output. You'll notice this same effect in your laptop charger if it is equipped with an LED indicator light letting you know it is energized.
May 08, 2014 | Power Tronic Computers & Internet
I need a wiring diagram and or a color code chart for the wires and plugs coming out of a "Power Tronic" switching power supply model SK-4145DE. 145 watt power supply. Thanks for your help.
Many power supplies have a chart on the side of the case.
Here are the wire colors for an ATX type supply:
RED +5, YELLOW +12, White -5, Blue -12, ORANGE +3.3,
PURPLE +5VSB, GREEN Power On, BLACK -Gnd (common).
Feb 14, 2010 | Power Tronic PowerTronic 145W Switching...
I have 3 color copy machines irc3200n,clc 2620 all this machines same probleme when i make test # 10 or any copy the colors dose not come togther this mean there is shadow and white ligne between the...
I have seen this many times with this model.Yiu replaced the ITB already. Next thing to do is a D-CON clear. But you better call a tech to do it for you.
Oct 14, 2009 | Office Equipment & Supplies
Cant find repalcement lamp for my tv
I have a repair shop I use that will find and order it for you. Talk with Frank SR. at Audio Tronics in Cherry Hill NJ his shop number is 856 6670190. Open 10-5m-f 10-2 sat sunday closed.
Mar 17, 2009 | Hitachi 62VS69 62" HDTV
Harman-kardon citation 7.1
Go to diyAudio.com and try asking there....
Jan 10, 2009 | Harman Kardon Audio Players & Recorders
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Probleme charge motorola l6
answers to ur questions
1.it is totally dependent on the charger.
2.yes it shows the charging
3.just cool
Feb 20, 2008 | Motorola Mobility RAZR V3
Health & Beauty Logo
123 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
