Question about Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361
Themastate stuck on hold reset but comes back to hold.
Won't start heater.
  • David Pallo
    David Pallo Nov 27, 2013
    thermostat stuck on hold reset and still on hold.
    Habit-Forming:
  • 188 Answers
Remove batteries for a minute and try again
Posted on Dec 12, 2013
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Oct 30, 2012 | Cell Phones
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Ican not reset nokia 2690 by using themaster reset code given in the site
Contact mobile repairing shop.This is the best way to fix your problem.Thanks for visiting fixya
Sep 06, 2011 | Nokia 2690 Cell Phone
My monitor is stuck on a webpage!! The mouse won't move,I turn it off and back on and it is still on the same website?
It's not the monitor that's stuck - it's the PC. Press and hold the power button of your computer for about 10 seconds - this should force the computer to turn off immediately.
When you turn it back on, it will tell you there has been a problem, you can normally skip any errors that come up, and choose "Start Windows Normally". and it will return as normal.
Aug 05, 2011 | Hannspree Computers & Internet
Electric water heater out. Already replaced elements and breaker. Getting power to the unit but no hot water. What now?
Have you reset thermostat on the heater, it will be the top thermostat right above the element. It will have a red reset button to press to reset. They will trip causing the heater not to work till it's reset or replaced due to thermostat gone bad. Chances are you may only have to reset it.
Please go to link below with to get some very helpful information on these topic's. If you replaced everything but the thermostat or reset it that's all left to hold out power to water heater. The thermostat is a safety device to protect the home owner. You may have had a element short out to trip it.
It will take 30 to 45 minutes to start to produce hot water after power comes back on.
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 17, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Heater blowing cold when set at hot
Hi, your engine sound run at 90 degrees when hot, if you change the themastate in the engine block sould cure the problem, if not bleed the heater matrix from the bulkhead with the engine running etc.good luck.
Feb 22, 2010 | 1998 Audi A4
Thermostats White Rodgers 1F80-261 thermostat is obsolete, CONSIDER 1F80-361 Logo
272 people viewed this question
Top Thermostats Heating & Cooling Experts
john h
Joe Lane
Are you a Thermostats Heating and Cooling Expert? Answer questions, earn points and help others
