Hi, we have a KX-T7330 panasonic telephone. I was able to see the date and the time, but now I can only see the date and the day it is: Nov 27, 2013 WEN. I don't know hoy to display my preference.
SOURCE: Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time,
and the extension information, press the "star" (or asterisk) key while
the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
SOURCE: Change the time and date on Panasonic KX-T7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
SOURCE: Panasonic KX-T7730 - changing time display
Following are the steps:-
PRESS: - PROGRAM (PITS PGM NO. APPEAR)
- *#1234
- 000
- Speaker (Date/Time will appear on the screen & blink
- Point directional sign to the desired position to change accordingly
Once finish with the above - Press "STORE" button
Then lift handset and replace
MT
SOURCE: hello, in our office we
Does the second soft key from the left display INFO? Press it one or two times.
Carl
Press "Program" and then the "0" button on the dialer to enter the program menu. Enter the date using the following format: year, month, day and weekday (Monday equals "1," Tuesday equals "2," and so on). As an example, Tuesday, Nov. 13, 2010 at 8:00 a.m. uses the following string of numbers: 101133 1 0900 2.Press the "Store" button on the phone base. Press the "Program" button on the base. Hang up the phone receiver
